A Series Block On A+ Gearbox?
4 replies to this topic
#1 connorwmc
connorwmc
  • 59 posts
Posted 14 October 2015 - 03:25 PM
I've searched and seen this explained the otherway around but couldn't make heads or tails of the answers
My question is will an a series block fit onto a a+ gearbox without to much trouble.
If I was to run into problems what would it be?
#2 Swift_General
Swift_General
  • 871 posts
Posted 14 October 2015 - 03:39 PM
Should be fine. Just make sure you use the transfer housing for the gearbox and A+ drop gears.
#3 robminibcy
robminibcy
  • 1,516 posts
Posted 14 October 2015 - 06:02 PM
as above yes. The late 70s early 80s minis came like this from the factory.
#4 Spider
  • 15,685 posts
Posted 14 October 2015 - 06:59 PM
Usually they go together OK as the other guys have said, though I've had a few when fitting an A 1275 to an A+ Gearcase, the back Main Bearing Bolt Heads touches the case and won't let them come quite together. A few minutes with a file on the Gearcase and problem gone. I haven;'t checked, but it appears on the A+ engines, the spot facings on the main Bearing Caps were slightly closer to the block.
#5 Dusky
Dusky
  • 5,322 posts
Posted 14 October 2015 - 10:48 PM
Had this problem after I did the calver mod on my crank bearing caps ( basicly usign a big moly washer to prevent the bolt 'eating' in the cap).
My advice: don't use a dremel or dont be too enthousiastic unless you want a hole in your casing :P
YEs, I'm stupid ;D
