hi everyone
Was hoping for some advice on what to try next with the misfire I thought I had fixed, but has returned after 2 weeks (3 drives - occasional use car)
If I drive from A-B normally without much acceleration its fine.. The problem occurs when I used 3/4 - full throttle over 3,000 rpm.
I did have the problem before like I said and I replaced the plugs, leads, dizzy cap and rotor arm, made sure the carb dash pot oil was at correct level, and after 5 mins of driving the problem went away... only to now retrun again.
any ideas?
only other thing to note is that a previous owner much of ruined the thread in the dizzy for one of the cap bolts, so that has always been held on by a cable tie.. when I changed the dizzy cap, srewed in one bolt and then used a new cable tie and secured the other side very tightly.. Obviously it sounds like this will be the problem, but the dizzy cap appears very secure!
Its not been driven in the wet at all in this time.
Engine is a 1275 MG Metro
many thanks
