Myself and a couple of freinds have just clubbed together and bought a sykes pickavant fault code reader,i have a spi and they have a couple of mpis,my question is today we tested it out and it worked fine on my spi with the rover 1 pod but would not communicate with the mpi using the pod 2 so i am thinking we need the rover pod 3 can anyone confirm this for me please before they buy one as they are quite pricey although they hope to sell the pod 2 if possible,thanks.
I was quite pleased with mine though it hasnt been scanned for years and the only fault that showed was the inlet air temp sensor which i replaced a few years ago and repaired the wiring for at the same time although oddly after clearing that and rescanning a bit later a fault showed up for the throttle pot which was also new a few years ago as well but it drives fine so think i can ignore these.
Even the lambda seemed ok giving similar readings to the sykes info in the instuction book.
