Oil Control Rings To Big
6 replies to this topic
#1 andyt
andyt
  • 375 posts
  • Local Club: cooper register
Posted 18 October 2015 - 01:28 PM
Im rebuilding my 1991 998 a+ engine and have just tried fitting my new piston rings that I ordered from Minispares and the oil control rings are to thick to fit in the groove, there are also 4 rings in the packaging and the pistons only have 3. I have checked the paperwork that came with them and it says 998 A+ std and the part number is the same on the box as the invoice, has anybody else had this problem or am I going completely mad!.
Andy.
#2 Dusky
Dusky
  • 5,322 posts
Posted 18 October 2015 - 02:08 PM
Just the wrong rings probably, Minispares sells 3 and 4 ring packages, depending on what piston it is.
Best to have a chat with them.
#3 andyt
andyt
  • 375 posts
Posted 19 October 2015 - 04:15 PM
Does anyone have any old oil control ring from a post 1988 a+ piston as I need the HEIGHT dimension as the ones I took off are in bits!
Andy.
#4 Dusky
Dusky
  • 5,322 posts
Posted 19 October 2015 - 05:44 PM
Andy.
: +- 2.78mm
+- 0.109 inch
Edited by Dusky, 19 October 2015 - 05:45 PM.
#5 andyt
andyt
  • 375 posts
Posted 19 October 2015 - 08:27 PM
Thanks very much.
Andy.
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 October 2015 - 03:26 PM
Oil control rings are 3mm or 4mm depending upon piston type, of which there are 3, two of which are circlip gudgeon pins will be a 4mm oil control ring, those which are interference (press) fit will be a 3mm oil control ring.
I suspect you have an R33636 ring pack, but later press fit pistons, I'm surprised any of the rings fit...
You need rover p/n BHM1629 or R43240
Edited by Guess-Works.com, 20 October 2015 - 03:28 PM.
#7 andyt
andyt
  • 375 posts
Posted 20 October 2015 - 06:47 PM
I only tried the oil control ring against the bottom groove and did'nt get as far as fitting the other rings once i knew i had a problem, you are correct in that i need the r43240 set as I contacted Gavin at minispares with the size of the old rings.
