Mini Engine 998Cc Jiggering And Rocking And Sounds Like Its Half Starting
14 replies to this topic
#1 classicminifittings
classicminifittings
  • 14 posts
  • Local Club: Staffs Minis
Posted 21 October 2015 - 01:10 PM
Hi all,
I was wondeirng if anyone can help/advise and point me in the right direction with my issue with my Mini mayfair 1990.
Engine is 998cc
I was on a journey and was working fine and stopped and then started again to return home and was ok, however got to top of thhe drive and it did a 'BANG!' and then a his noise, I stopped and then the engine turned itself off, I was also low on fuel and just going on the 'red' I am not sure if its a blockage, but left it for a few moments and tried again once cooled.
Now it rattles the engine like when you start the car and keeps going... like little revs and then dies then little revs and dies type sound. It might be a backfire.
Tried some petrol treatment and no luck, the distubitor cap (dizzy) was fine before and hasn't moved. vac pipe all clear and air from the air filter is ok.
Could anyone advise what to look for and how I go about checking etc.
Also choke cable ok
#2 Spitz
Spitz
  • 1,716 posts
Posted 21 October 2015 - 02:15 PM
Double check that your grounding strap has not come off/corroded etc.  It is usually on the right side of the engine bay, connected to the clutch housing.
Would have similar symptoms
...it does sound fuel related though
#3 classicminifittings
classicminifittings
  • 14 posts
Posted 21 October 2015 - 03:37 PM
Thank you for your post, I will check this and yes sounds like a fuel / blockage.
#4 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 21 October 2015 - 03:52 PM
have you popped the lid of the float chamber and see if there is fuel in there? coulld always try the old cap full of fuel down the carb and see if it fires.
The loud bang and his sound rather odd though!!
#5 David128
David128
  • 644 posts
Posted 21 October 2015 - 06:07 PM
Just a thought and might be way out. Is the distributor body fixed tightly ie you cant move it? This happened to me once.
#6 classicminifittings
classicminifittings
  • 14 posts
Posted 22 October 2015 - 02:22 PM
My mini fires up, but its just not firing right
#7 classicminifittings
classicminifittings
  • 14 posts
Posted 22 October 2015 - 02:51 PM
Here is the video link to my mini and what is happening:
The whole engine moved like its fired but not firing properly, dizzy cap is ok haven't touched it or changed it appart from htc leads new put on in december last year.
Need a quick fix as MOT end of month !! Whoops!
#8 David128
David128
  • 644 posts
Posted 22 October 2015 - 03:31 PM
It sounds like its strangled is the exhaust clear? Could be a collapsed or partially blocked silencer
#9 classicminifittings
classicminifittings
  • 14 posts
Posted 22 October 2015 - 03:52 PM
Just checked exhaust is clear stuck a metal pole in and nothing there and ok, it could possibly be blocked up but no holes in exhaust (appart from the exit pipe) lol.
Starting to really bug me, but when come to rev more and more and on full choke the engine then dies and does like an engine stall.
#10 Carlos W
Carlos W
  • 10,114 posts
Posted 22 October 2015 - 03:56 PM
Take the plugs out, do they all look the same?
Have you got a compression tester?
#11 David128
David128
  • 644 posts
Posted 22 October 2015 - 04:04 PM
Another thought low on fuel .. muck from tank restricting fuel delivery. The bang and hiss made me think of blocked exhaust. it could still be a restriction there not blocked when not running but picked up when actually running.. Easiest way is to tap silencer not too hard and listen for rattles in side.
#12 classicminifittings
classicminifittings
  • 14 posts
Posted 22 October 2015 - 04:15 PM
Thank you David, I will try this tomorrow afternoon and have a good go.
It happened so quickly the bang and hiss noise as I live on top of a hill and maybe fuel becuase was low it might have done that. Thanks David I shall give it a go tomorrow :)
#13 classicminifittings
classicminifittings
  • 14 posts
Posted 23 October 2015 - 04:17 PM
I tapped it with a plank of wood as you do, and still no luck swapped rubber around carb and aur filter box no difference
#14 Carlos W
Carlos W
  • 10,114 posts
Posted 23 October 2015 - 04:27 PM
#15 Spitz
Spitz
  • 1,716 posts
Posted 23 October 2015 - 05:06 PM
You havn't mentioned if you've checked that the ground strap is attached
Just watched your vertical video ( people, please turn your phones around ), your choke is fully pulled out for the duration.  I think most of our cars will run like that with the choke fully out.  It should only need pulling out for initial start, then pushed in half.
I would be checking your carb settings, likle fast idle adjustment.
When you push the choke all the way in....does the engine stop?  If so, try turning the idle up until it will run without the choke.
Edited by Spitz, 23 October 2015 - 05:11 PM.
