Gear Ratios
4 replies to this topic
#1 chris27989
chris27989
  • 40 posts
Posted 23 October 2015 - 02:29 PM
Hi,
I'm very new to the mini world. Ive always wanted a mini and my knowledge of them is growing massively.
I was wondering how the gearing ratio works?
And how you dictate what gearing ratio is correct for you engine?
Regards
Chris
#2 gazza82
gazza82
  • 3,018 posts
  • Local Club: TMF+
Posted 23 October 2015 - 03:08 PM
Could start here ... http://www.guess-wor.../Tech/ratio.htm
#3 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,859 posts
  • Local Club: man Estate
Posted 23 October 2015 - 05:28 PM
Do you mean Final Drive (FD) or the gear ratios?
Your question makes me think you're asking about the FD?
#4 Spider
  • 15,102 posts
Posted 23 October 2015 - 06:42 PM
Not sure of your opening question "How Gearing Ratio Works" but if you were wanting to know some Gearing Basics, there are loads of Youtube clips that explain and show these aspects very well.
If I can expand a little on Mini Manannan's post.
There are 3 sets of gears on a Mini you can swap around to get different ratios from;-
      The 'Drop' Gears - which are between the engine and the input of the gearbox,
      The Gearbox itself, and
      The Final Drive (FD) or Diff gears
Once fitted, the Drop Gears and Final Drive ratios are fixed, only those in the gearbox are 'variable' but across 4 'fixed' steps.
Basically the selection of ratios comes down to what the engines characteristics are and what the car is being used for.
#5 Wim Fournier
Wim Fournier
  • 177 posts
Posted 26 October 2015 - 06:21 PM
Indeed, there are three sets of gears on a Mini.
But don't forget to take in account the wheelsize your car has and the section of the tires that you use.
In the end is it the circumference of the road wheels that make the meters.
