Good morning mini people!
I recently got 4 pots for my mini and before fitting them I would like to sort out an issue I have.
When I'm hard on the brakes the rears lock up way before the fronts do which wears them down alot quicker and makes the handbrake useless without constant adjustment. I get the feeling the brake bias valve has gone and rather than just replacing it I thought about getting a manual one like the Wilwood one so I can fine tune the front/rear balance, I'm far from an expert so any advice would be great (tell me if this is the wrong way to go about it!).
I have the black tag master cylinder which has two feeds going to the brake balancer then to the brakes, If i just connected the front brake lines together bypassing the valve and used the Willwood brake valve to connnect the rear lines would that be what I'm after? I also heard the yellow tag master cylinder is better but mine works just fine so it would be a shame to replace something thats works?
Now.. the next item on the agenda.
I have the standard MG metro engine in and I'm looking to add a few extra horses to the old british stable! Not anything crazy but I'm thinking a new head and rockers, From what I've read it seems the a-series 'breathing' is something that can be improved. I don't want to take the engine out and from what I've read the metro cam isn't actually to bad. This is where I'm stumped, I have a working knowledge of the suspension and brake setup as I have messed with it quite alot recently but engines are something I have never really done anything with. I'm keen to learn and would like to do the work myself, obviously polishing and porting a head isn't a 'diy job' so some advice would be great. I've ordered David Vizzards A-series tuning book for some more knowledge so hopefully that will help. I've also thought of full electronic ignition by Aldon amethyst or maybe even taking the leap to megajolt but I get the feeling that might be overkill!
Any help is appreciated!
my setup is just standard metro engine with the accuspark electronic ignition module.
