Mini 1340 Compression
Posted 24 October 2015 - 11:43 PM
Posted 24 October 2015 - 11:45 PM
Something is not right.
Posted 25 October 2015 - 12:09 AM
What is a normal pressure reading for and engine like this?
Posted 25 October 2015 - 12:39 AM
Compression test results are very hard to compare. You have too many variables to take into account ( what tester you use, what starter, what camshaft ( they alter dynamic compression) , how well the battery was charged, was the engine hot or cold? thotttle wide open?,...)
BUT your results indicate something wrong on the outer 2 cylinders. Every cylinder should be atleast be within 10psi of the other.
Could be valve seats, could be pison rings.. Pistons rings can be comfirmed by putting a bit of ol in the bore and then testing again if I recall right?
Posted 25 October 2015 - 05:50 PM
175-190 would be typical compression pressure for a 1340 running CR of about 9:1 and a fairly standard road cam
All of the readings should be repeatable to better than 5psi, and all should ideally be within a range (min to max) of about 10psi
Posted 26 October 2015 - 01:22 PM
