That's a single line pedal, so either someone swapped the whole caboodle, or the pdwa is the imposter.
http://www.minimania...tia_brake_valve
Posted 26 October 2015 - 07:49 PM
Posted 26 October 2015 - 08:03 PM
The Valve has an arrow with the words "FRONT" cast in to the body of it. The line of the Arrow needs to be more or less level;-
This is the only photo I have on this PC of them fitted up;-
but I doubt that's your issue here.
Edited by Moke Spider, 26 October 2015 - 08:07 PM.
Posted 26 October 2015 - 08:04 PM
Except for the carbs and incorrect rad, your engine bay config should look like this...that is the master cyl your car would have come with. My guess is someone has salvaged bits off an older car ( pictured is a 77, so the pdwa may differ slightly
I have a pic of a stock 75 engine bay somewhere.....
Edited by Spitz, 26 October 2015 - 08:05 PM.
Posted 26 October 2015 - 08:19 PM
Found...This is a 75...tough to see the valve, but appears to be the same. Correct brake master.
Notice the correct rad and thermo housing...this was to accomodate the airpump ( not important here I know )
Posted 27 October 2015 - 04:53 AM
Thanks everyone! Iv ordered a "T" to replace the weird junction block on the bulkhead. I will make sure the bias valve is in the correct orientation, and see how the brake bias is, after that and go from there.
Thats cool to see how my engine bay is meant to look. For comparison here is my current engine bay
Posted 27 October 2015 - 08:23 PM
Where is your crank case vented to? If you get a "T" you could hook the valve cover into it and do away with that little filter.
Much tidier than the pic of my old 75...lol
Posted 27 October 2015 - 09:18 PM
that picture is a little out of date, the crank case vents into the carb now.
Posted 27 October 2015 - 10:26 PM
You must have some seriously heavy duty screen wash jets going by that hose ![]()
Canuk winters eh?
Posted 27 October 2015 - 10:41 PM
Canuk winters eh?
I am guessing that (based on the direction of the hose) it is not being used as a windshield wiper reservoir but a radiator overflow bottle.
Posted 28 October 2015 - 12:14 AM
Canuk winters eh?
you would be correct. The washers didn't work anyways and it was in a good location so I put it to use.
Posted 28 October 2015 - 08:50 PM
Posted 28 October 2015 - 08:55 PM
But doesn't that make your windscreen streaky?
Like this?
Posted 28 October 2015 - 11:36 PM
I'd have thought all Ozzie Min's would leak like that, what with them being upside down 'n all.
