Which Bracket To Mount Relay And Where?
7 replies to this topic
#1 rodandtom
rodandtom
  • 998 posts
Posted 28 October 2015 - 03:34 PM
Hi,
What does the bracket look like to mount this relay and where does it bolt on to please?
Ta
Rod
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 October 2015 - 07:50 PM
The bracket for relays is a dogleg bracket and they fit in a slot in the yellow case as per the picture below,if your relay has no slot its designed for push in fitment in a fusebox, you can also get a 4 terminal where the bracket is part of the casing. Location wise if you raise yours vertical on the wiring back against the inner wing thats roughly the position
Edited by KernowCooper, 28 October 2015 - 07:52 PM.
#3 rodandtom
rodandtom
  • 998 posts
Posted 28 October 2015 - 09:36 PM
Hi
sorry I wasn't clear. I know how it physically mounts on a bracket. I was wondering what bracket others use and where do they put it on the inner wing.
Thanks,
Rod
#4 adam_93rio
adam_93rio
  • 3,271 posts
Posted 28 October 2015 - 10:04 PM
Mine has the factory bracket on there. I'm sure there's a captive thread that it bolts to
#5 johnR
johnR
  • 2,297 posts
Posted 28 October 2015 - 10:16 PM
I think mine had a plastic captive nut - I re-made the bracket into a double one and mounted the spotlamp relay there as well to keep it company.
%5BIMG%5Dhttp://i76.photobucket.com/albums/j32/johnR21/fuse%20box_zpskqhk8cne.jpg
#6 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 29 October 2015 - 08:44 AM
Or you can tape it back to the original loom - it wont hurt at all.
Failing that I can send you either a plastic mount to use and you will have to remove the terminals from the current plug and fit them in the housing, or I can send you a dog leg metal mount if your relay has the slot as mentioned above.
David
#7 rodandtom
rodandtom
  • 998 posts
Posted 29 October 2015 - 06:47 PM
I may well already have the bracket. I just wanted a photo of what it looked like and where it was mounted if anyone can oblige.
Ta
Rod
#8 johnR
johnR
  • 2,297 posts
Posted 29 October 2015 - 10:57 PM
If you open the link on my previous post above(sorry I cant seem to display the pictures) you'll see the photo you're asking for
JohnR
