Rear Fog Light
6 replies to this topic
#1 connorwmc
connorwmc
  • 59 posts
Posted 30 October 2015 - 05:05 PM
So my car failed its mot on not having a rear fog light, so i got a cheap lamp from halfords
are these the existing wires of the fog light? if so which one is positive ? thanks Attached File  IMAG1838.jpg   68.97K   18 downloads
#2 Cooperman
  • 23,309 posts
Posted 30 October 2015 - 05:14 PM
You need to get a circuit tester and see which is which and confirm that there is power when the rear fog light is switched on. A circuit tester is very cheap and will enable you to work on the electrics in the future.
Also get a manual with a circuit diagram which shows the colour codes for the wiring. BS-AU7 is the British Standard for wire colour codes.
#3 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 30 October 2015 - 06:59 PM
Blue/yellow is the power supply from the switch, black is always earth on a mini.
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 30 October 2015 - 07:38 PM
Quote - black is always earth on a mini. @Wiredbywilson
Thats the standard wiring colour, unless the diy wiring expert has been there, and then it could be any colour, even 2 or 3 different colours on the same run. I stripped out all the inside circuits on a MGB all wired in Blue, feeds, earth the lot, I always check now if the wiring does not look standard
#5 ad444t
ad444t
  • 96 posts
Posted 31 October 2015 - 10:01 PM
What year is your car as mine hasn't got a rear fog but mine is 1979!
#6 Swift_General
Swift_General
  • 871 posts
Posted 31 October 2015 - 10:18 PM
Rear fog not obligatory until april 1980
#7 Cooperman
  • 23,309 posts
Posted 31 October 2015 - 10:37 PM
It looks like the OP's car is a 1990, so a rear fog is required.
