Grinding Wheel Studs Back
8 replies to this topic
#1 Bodhi
Bodhi
  • 22 posts
Posted 30 October 2015 - 08:08 PM
Im having problems with wheels studs and thinking of grinding back the clearance a bit to tap more thread so they do up. Where I've got 10 x 6 mambas and superfins on the back and converted the front to disks I've got the longest studs and middle studs but I need the I between sizes ideally. Has anyone successfully grounded back and tapped more thread safely? It's only 7mm more thread and grinding back 1- 1.5 mm of girth.
Thoughts?
#2 Bodhi
Bodhi
  • 22 posts
Posted 30 October 2015 - 08:10 PM
The title was supposed to be ( grinding wheel studs back)
#3 Carlos W
Carlos W
  • 10,114 posts
Posted 30 October 2015 - 08:11 PM
Sorted for you
#4 Bodhi
Bodhi
  • 22 posts
Posted 30 October 2015 - 08:43 PM
#5 nicklouse
  • 18,618 posts
Posted 30 October 2015 - 08:53 PM
You will not be cutting thread in the studs.
What is the actual problem?
#6 Spider
  • 14,942 posts
Posted 31 October 2015 - 12:00 AM
HT Studs like these are made (or should be) by a rolled thread method, they are not cut. I would not recommend making the threads longer by cutting them. Threads made by cutting (eg a Die) make the parent material weaker.
#7 nicklouse
  • 18,618 posts
Posted 31 October 2015 - 12:16 AM
True there is that. But to be honest it just sounds like you have the wrong studs. Never had to do anything to the studs I fitted when I ran the same wheels.
#8 Ethel
  • 25,980 posts
Posted 31 October 2015 - 09:46 AM
Not sure exactly which studs, nuts, wheels you mean. Assuming they are tube nuts, you'd very likely be better off drilling the threads out of the nuts and trimming the stud ends if needed. That is if you'll be left with as much thread engagement as a conventional wheel nut. See how much thread engagement there is with the next shorter stud first.
#9 Bodhi
Bodhi
  • 22 posts
Posted 31 October 2015 - 01:20 PM
Cheers guys, I've had two other people say about how messing with the wheel studs can weaken them so in the thought of safety I'll wait till the right nuts arrive.
