Waxoyl/dynax/.. Locations
6 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 01 November 2015 - 03:46 PM
Hi guys!
I've been researching how to rustproof the mini in the last few weeks.
Sadly my precious P has crashed ( well, the motherboard is fried, so if anyone knows where to buy a new one for a toshiba L70 b 132... :") )
Anyway, I had this great picture of where to drill holes etc to apply waxoyl/dynax/...
But I can't find it anymore, nor on the web. ould anyone help me?
many thanks!
#2 sledgehammer
sledgehammer
  • 3,098 posts
Posted 01 November 2015 - 05:02 PM
take the hard drive out ,
fit an USB to 2 1/2 inch ide or sata adapter to it ,
then you should be able to read it
they are cheap enough
can't find the info you want with a search on google - must be out there somewhere
Edited by sledgehammer, 01 November 2015 - 05:18 PM.
#3 Dusky
Dusky
  • 5,322 posts
Posted 01 November 2015 - 05:10 PM
I have the equipment to do that, but need to hand in the Full laptop for warranty, and didnt think I d need anything on it the comming weeks.. Rushed it and now bear tje consequenses lol :/
#4 sledgehammer
sledgehammer
  • 3,098 posts
Posted 01 November 2015 - 05:20 PM
know what you mean - hind sight is a wonderful thing
been looking for the info on google - can't find it - would be usefull
#5 some1158
some1158
  • 369 posts
Posted 01 November 2015 - 05:49 PM
I don't have the diagram, but the guide I've used (taken from a thread somewhere on here) is:
Starting at the front: The small box sections in the front panel where the subframe mounts are, accessed through the access hole in the front panel.
Bonnet stiffeners, particularly the front ends, accesses through various holes in them.
Scuttle corner box sections, access from engine compartment, there is a gap between scuttle & inner wing.
A-posts, access via hole where door check bracket operates.
Sills, either drill a hole in each section fore & aft of the jacking point & fit grommets afterwards, or insert lance via the sill flutes
Seat mounting box section, access through holes already there.
Doors, remove pockets, if fitted & release bottom of door card.
B-posts, there is a black plastic cover, facing the rear of the car which can be removed & you can spray into there.
Side-bins & rear sill sections, remove trim from sidebins & spray waxoyl liberally into the rear heelboard end & down the side panel, There is also a sill box section in there & with a waxoyl extension probe, you can get to that from the hole drilled in the sill section behind the jacking point.
Rear wheel arches, not exactly a box section but it's important to allow waxoyl to run all around the inside where the arch meets the side panel.
Inside boot, small box sections where rear bulkhead, boot floor & wheel arch all meet, access through holes already there.
Boxed ends of rear valance, if it's original & 1980-on you can access the right hand one through a hole in the corner of the boot floor where the rear fog light wires run. Left hand, remove grommet beneath bumper which covers the hole for a second rear fog mounting.
Stiffeners in bootlid, via gaps between stiffener & skin, put plenty at the bottom of this.
#6 gazza82
gazza82
  • 3,015 posts
  • Local Club: TMF+
Posted 02 November 2015 - 10:03 AM
Get your pics and info off first Dusky ... the warranty people might scrub your disk!
Edited by gazza82, 02 November 2015 - 10:04 AM.
#7 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 02 November 2015 - 07:20 PM
They usually do that anyway it's pretty much standard procedure to return to factory settings.
