Engine Block Level
4 replies to this topic
#1 the general lee
the general lee
  • 23 posts
Posted 01 November 2015 - 11:10 PM
Hi all,
Just a quick question- is the mini engine block level? As in if I remove the head and the car is on a known level ground, is the top of the mini block level, both longitudinal and transverse (parallel to the ground)?
I need some reference points and was wondering if this i a way I can use for a datum. Or is there some point of the front subframe that is parallel to the ground? Hope someone can help,
Cheers,
Lee
#2 Alex_B
Alex_B
  • 4,573 posts
Posted 01 November 2015 - 11:12 PM
Very unlikely, it is mounted on rubber engine mounts so it can't be relied on being level.
#3 nicklouse
  • 18,606 posts
Posted 01 November 2015 - 11:20 PM
And also the height can change as the engine mounts age.
#4 carbon
carbon
  • 2,590 posts
Posted 02 November 2015 - 07:09 PM
In general terms the top of the block should be level in both directions, but may not be in practice for the reasons given above.
Top mounts of the front subframe should also level side to side. There are some other pointers on subframe alignment in the old BMC factory workshop manual Section R.
Why do you need a level reference/datum?
#5 Spitz
Spitz
  • 1,716 posts
Posted 02 November 2015 - 07:47 PM
You can get an adjustable dog bone,,,,this would allow slight tilting of the block if need be.
