Im wandering if someone can tell me the degree of taper on the crankshaft flywheel end, ive stripped the engine and all journals are fine but i can feel some highspots on the taper so was planning on just giving it a couple of thou lick on external grinder at work , I don't plan on taking much but am thinking that so long as the flywheel does not interfere with the horseshoe clip then it should be fine ! also are there any recognised flywheel modifications that are worth doing.
Thanks.
