Hi
If you have a Lynx R1 conversion fitted would you mind measuring the height of the engine sump from the lowest and flatest part of your subframe. I would be very grateful to anyone who can do this for me.
I'm trying to figure out how high to mount the engine relative to the lowest point of the subframe. Based on the photos I've seen I am guessing its about 40 mm so when the exhaust passes underneath that will be approx level with the bottom of the subframe?
Final question - how level is the bottom of your sump realtive to the ground/bottom of the subframe? Does the front of the sump angle up slightly putting a slight tilt on the engine making it lean backwards?
Many thanks
Luke.
