Need New Rocker Cover Gasket
8 replies to this topic
#1 jameseddolls
jameseddolls
  • 110 posts
Posted 11 November 2015 - 07:07 PM
Hi so I've got a question about a new rocker cover gasket. I know that the original is made out of cork, but was wondering if anyone knew if i could get a gasket cover that it is made out of rubber and can fit a rover mini 1000, 1991 model. I'm not sure how many studs are on the car itself if it is 9 or 11 but your help would be much appreciated, have got a Haynes manual as well by the way.
#2 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 11 November 2015 - 07:41 PM
http://www.rimmerbro...--i-12A1175EVAP
#3 mk1leg
mk1leg
  • 9,343 posts
Posted 11 November 2015 - 08:48 PM
you can get silicone gaskets now  http://www.minispare...px|Back to shop
#4 Rocket.
Rocket.
  • 1,441 posts
Posted 11 November 2015 - 09:01 PM
I've used the newer type of gaskets but i always find myself going back to cork it just seems to seals better
#5 jameseddolls
jameseddolls
  • 110 posts
Posted 11 November 2015 - 09:03 PM
Cheers guys,n,I have appreciated. Gonna order the second one suggested
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 11 November 2015 - 09:42 PM
To prevent the sealing issues Rocket mentioned, see the thread linked below and follow the steps I outline in post #9 (first page).  If you follow that method the silicone gaskets work very well.  This method also works very well with cork gaskets if you prefer to continue using them.
http://www.theminifo...-rocker-gasket/
#7 Rocket.
Rocket.
  • 1,441 posts
Posted 11 November 2015 - 10:18 PM
Thanks for sharing
#8 spiguy
spiguy
  • 1,537 posts
Posted 11 November 2015 - 11:09 PM
I have found that simply not overtightening the cork gasket (ie not overtightening the rocker sleeve nuts) is the answer. I fitted t bars to make it easier. Just nip them up but don't horse them down, and the cork gasket seals fine for a long long time.
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 12 November 2015 - 12:16 PM
That is indeed true if the valve cover is not distorted from previous owners over tightening the sleeve nuts.
The gasket installation method I posted a link to works both for valve covers that are pristine and those that have been distorted from previous owners over tightening and distorting the valve cover.
