I have assembled my pre-Verto clutch. I have installed a new release bearing and adjusted the bearing-to-flywheel housing clearance to 3/16" using the return stop bolt shown in the images. I am concerned that there seems to be very little plunger travel when I actuate the clutch lever. Maximum travel is only 1/8", measured as shown between the return stop and lever. The plunger stop and locknut are backed fully off, and they are not limiting the plunger travel. What is the normal amount of lever travel at this location?
PICT0010.JPG 54.45K
6 downloads
PICT0008.JPG 49.2K
7 downloads
