Will A Mini Engine Fit In A Honda Jazz
22 replies to this topic
#1 Daniel_moody25
Daniel_moody25
  • 407 posts
Posted 13 November 2015 - 04:49 PM
Simple as really I would like to know if a built mini engine will fit in a 2002 ish Honda Jazz
#2 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 13 November 2015 - 04:53 PM
Yes, but more interestingly, why would you?!
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 November 2015 - 04:54 PM
Of course, even if you fold the seats down.
The biggest problem is getting it in and out unless you have a hoist both ends
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 November 2015 - 04:55 PM
To get it home....
#5 Daniel_moody25
Daniel_moody25
  • 407 posts
Posted 13 November 2015 - 05:02 PM
Well I don't particularly want to put it in the mini and I'm not old enough to hire a van and can't find anyone that will lend me one so had a mate offer his jazz
#6 Will16
Will16
  • 1,090 posts
Posted 13 November 2015 - 05:06 PM
To get it home....
Completely mid-read that, I was thinking the OP wanted to power a Jazz with a Mini engine.. ffs!
#7 nicklouse
  • 18,769 posts
The typical not quite giving enough info.
So you don't want to put it in the Jazz just move it in a Jazz.
#8 Corey96Williams
Corey96Williams
  • 316 posts
Posted 13 November 2015 - 05:21 PM
To get it home....
I thought exactly the same  :lol:
#9 Matt's Dad
Matt's Dad
  • 34 posts
  • Local Club: Falcon M.C.
Posted 13 November 2015 - 05:33 PM
Have done something similar into a Toyota Yaris... If the gearbox is attached you've got yourself a real challenge. Realistically if you don't have a hoist, you're going to need a lot of manpower and some significant protection around the tailgate lip. Like a couple of planks to slide it across the lip... And some strops to lift the engine with... and a lot of thought about how you're going to rotate the engine as needed to get it in, and again, a lot of muscle...
Good luck.
#10 Daniel_moody25
Daniel_moody25
  • 407 posts
Posted 13 November 2015 - 05:37 PM
Yes it is to move the engine from one place to another not to power the Jazz
#11 sledgehammer
sledgehammer
  • 3,109 posts
Posted 13 November 2015 - 05:47 PM
To get it home....
same here
#12 Ethel
  • 26,185 posts
Posted 13 November 2015 - 06:10 PM
It'll go in a Mini fairly easily in place of a front seat. You could chop up a pallet to make a platform level with the doorstep. Lash and chock it in well. Sure you could do the same if your mate doesn't mind you dismantling his car.
#13 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 November 2015 - 06:48 PM
To get it home....
same here
I thought it was pretty clear :lol:
#14 Daniel_moody25
Daniel_moody25
  • 407 posts
Posted 13 November 2015 - 06:53 PM
To get it home....
same here
Thanks, I didn't think it was too unclear
#15 sledgehammer
sledgehammer
  • 3,109 posts
Posted 13 November 2015 - 08:38 PM
now it's clear you want to transport a mini engine in a honda jazz ...
as above pallets to get the hight , plank to slide across the door step
strip of carpet under the gearbox , pull on the strip to move it -
much more stable than trying to move the engine higher up when it's in the car
a spade is also a good way to drag it on the ground , to get it to the car
use ratchet straps to secure it in the car , not safety belts
fit in passenger side where seat was - if in boot - not on spare wheel , some where it can be clamped with ratchet strap
old blanket to stop grease getting into carpet
remember the engine will have high inertia - so drive smoothly ,
Edited by sledgehammer, 13 November 2015 - 08:40 PM.
