Quick clutch bleeding question.
Do you bleed the clutch after setting the mechanical freeplay on the bolt and big nut, or before. My thinking being, that if the mechanical freeplay is all backed off when bleeding, you can get the full motion of the hydraulics, without them being impeded by the stoppers. However, with the stopper set first, you have a finite amount of play to work within to get the air out.
thoughts?
