How To Tell A Genuine Cooper From A Repro...
8 replies to this topic
#1 PaulColeman
PaulColeman
  • 712 posts
Posted 14 November 2015 - 09:27 PM
How do I tell a genuine 1966 998cc Cooper from a 'look-alike'? This one has only one filler cap and I thought the Coopers had 2? Is there a difference in the chassis numbers? What about other tell-tale signs to look for? Where would the chassis numbers have been on a 1966 car?
What sort of price would you expect to pay for a restoration project which has been off the road for 10 years and needs a full restoration?
Thanks, Paul.
Edited by PaulColeman, 14 November 2015 - 09:45 PM.
#2 sledgehammer
sledgehammer
  • 3,108 posts
Posted 14 November 2015 - 10:31 PM
I think cooperman - or the cooper register will be the best people to ask
how many fuel tanks has it got ? cooper s had the extra tank
brackets to support the boot board - riveted up to 1966 spot welded in place after 1966
is it hydro elastic ?  21 hydro-elastic pipe clips spot welded to it , if original wet cooper
servo holes in inner front wing for servo ?
if it has been used for rally or racing or even normal use , it may have gone thru several shells in it's early life
I take it the shell is a mk1 ?
am I right in thinking the chassis number was a screwed plate on the radiator cowling ? that could be swapped from car to car
does it have 2 gear lever holes - nearest to the bulkhead plated over ?
as for a value - everyone wants it to be a genuine barn find -
but it's a 49 year old car , it will be a bit of a triggers broom
http://www.minimania...ification_Guide
edit - just re-read - cooper not cooper s - modified text for cooper
really could do with some pic's - esp engine bay & boot
Edited by sledgehammer, 14 November 2015 - 11:09 PM.
#3 nicklouse
  • 18,696 posts
Posted 14 November 2015 - 10:36 PM
Also twin tanks were only standard on the S from 66.
But saying that depending on the earlier owners twin tanks could have been a period addition or even a factory option.
So in that case you will need a good paper trail.
As they say without provenance it could be anything.
#4 Daz1968
Daz1968
  • 2,058 posts
Posted 14 November 2015 - 10:37 PM
Chassis number should start ca2s7 if austin ka2s4 if morris, but as for the shell there are tell tale signs such as factory cut out for remote gear lever, plate over magic wand gear lever hole, boot board brackets spot welded to seat bulk head, rivets on door frames for stainless trims,
998 cooper only had single tank as std, you really need to read up on it or take someone who knows cooper cars.
Value will really come down to condition and amount of parts missing so not easy to judge without more information.
Edited by Daz1968, 14 November 2015 - 10:39 PM.
#5 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 15 November 2015 - 09:05 AM
There is a really good book about the Cooper and Cooper S. Tells you all the variations, and changes with relevant chassis numbers and engine numbers.
Worth buying if your serious about getting one.
#6 PaulColeman
PaulColeman
  • 712 posts
Posted 15 November 2015 - 08:13 PM
Thanks all - I'll see if I can get some pictures of the engine bay but the car doesn't appear to have been messed about with and looks original from what I can see.
Assuming it's complete and not a basket case is £6,500 reasonable?
Cheers, Paul.
Edited by PaulColeman, 15 November 2015 - 08:14 PM.
#7 AlexMozza
AlexMozza
  • 1,248 posts
Posted 15 November 2015 - 09:06 PM
Any link to pictures or advert?
#8 ace01
ace01
  • 457 posts
Posted 16 November 2015 - 03:00 PM
John Parnell's book Original Mini Cooper and S is the book to get.  Alternatively the MCR have a buyers guide that is basic but good.  If you have pictures, put those up.
#9 Spitz
Spitz
  • 1,716 posts
Posted 16 November 2015 - 04:48 PM
See what speedo it has...I think the 998 would be 100mph
Disc brakes might be the original 7"
Possibly chroime trim around door window frame
Remote gearshift
Check the engine #
Head should be 12g295
