All four plugs are sparking but after removing and inspecting the plugs, I noticed the the plug from cylinder 1 is clean as new, there is only clean unburnt fuel on the plug. The other 3 are all sooty. Replaced the plugs and still the same thing happening, cylinder 1 spark plug is always clean. There seems to be nothing happening in the cylinder.
I have checked the gaps, done a compression test (125 psi at all 4 cylinders). Set valve clearance 0.30. News points, new condensor. Timing done, static and strobe.
The only fault that I have found was the vacuum diaphram isn't working, considering that the distributor is almost 50 years old, I will buy a new one. The coil seems to be the only thing never changed from new (1968).
I have no idea, please help.
Thanks. Rob
Edited by minitalia1275, 15 November 2015 - 08:15 AM.
