Hif 44 Too Much For A 1310 Standard Engine?
10 replies to this topic
#1 Agus1601
Agus1601
  • 148 posts
  • Local Club: La Tribu Mini
Posted 15 November 2015 - 09:59 PM
Hi guys! I bought long ago an hif 44 totally remanufactured. Was in awesome condition. I have it running for like three years now and I can´t reach same max speed I did with my hs4. It seems to have more torque but nothing really exciting...
At the moment my config is:
Distributor: 123 at curve 4
Coil: Bosch Grey
Spark Plugs: NGK BP8EIX
Engine: 1310cc + Some modified cam (done in my country)
Compression: It is a high compression. Like 11:1
Carburettor: Hif 44 + K&N (cone) + BBW needle
Also, today I decided to open the carb and it was completely black, like something is not running good at all. It seems to have a lot of fuel compumption. I use an old electric fuel pump.
What would you recommend me doing?
Agustin
#2 mingy
mingy
  • 930 posts
Posted 15 November 2015 - 10:56 PM
Hi Agustin ,
                        An HIF 44 should be fine for your 1310,  I would recommend you have your engine setup on a rolling road if you know a garage or workshop that has one as, this is really the only way to have the engine setup to run at it,s best.
#3 Swift_General
Swift_General
  • 871 posts
Posted 16 November 2015 - 12:07 AM
+1. The HIF 44 was fitted as standard to the 1275 Coopers before they went over to fuel injection in the early 90s so is a good carb to have and leaves a lot of tuning potential before you ever have to think of anything bigger. Hard to comment on the rest of you engine as there seens to be a lot of unknowns.
#4 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 16 November 2015 - 12:52 AM
Twin HS4 carbs. :wub:
#5 Dusky
Dusky
  • 5,322 posts
Posted 16 November 2015 - 06:15 AM
Your sparkplugs are way too cold.
#6 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 16 November 2015 - 06:52 AM
Like Dusky says, your spark plugs sound a bit on the cold side, an NGK BP7ES would be better, even a BP6ES.
 What do you mean the carb was completely black?  The inside of the carb or the outside?  Some pictures might help with that question.
#7 Dusky
Dusky
  • 5,322 posts
Posted 16 November 2015 - 07:00 AM
Bp6 for a standard engine, on hotter engines its a bit of hit and miss to Find the right one :)
#8 Leonrjohnson
Leonrjohnson
  • 166 posts
  • Local Club: MOCQ Far North
Posted 16 November 2015 - 10:55 AM
I have a HIF44 with Cone filter on my 970 S engine. Also have a 123 distributor with no vacuum advance. After lots of road tests and Air/fuel ratio trials, I have found that a BBW needle and Curve F works the best for me. I have 10:1 compression ratio, and a 731 cam.
If I can get mine to work on a 970, then 1310 should be ok too. I also run BP7ES plugs
#9 Agus1601
Agus1601
  • 148 posts
Posted 16 November 2015 - 07:28 PM
The inside of the carb is completely black!!! I will take some pics tomorrow
#10 Agus1601
Agus1601
  • 148 posts
Posted 16 November 2015 - 07:30 PM
Thanks for your help!!! I will be testing to use curve 6, but I have not a racing cam. Also it feels too rich in low/mid range (2000-3500) but then it goes ok. Also missing some hi speed end, it just went 140kph last weekend :(
#11 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 16 November 2015 - 07:50 PM
I've heard that none of the curves on the 123 distributors are ideal, maybe a reasonable compromise, but not ideal...
