Radiator Leak
12 replies to this topic
#1 mr_chris93
mr_chris93
    Starting My Mini Up
  • 1 posts
Posted 19 November 2015 - 10:21 AM
Thread answered. Thanks
Edited by mr_chris93, 13 August 2020 - 04:26 PM.
#2 Dzmarc
Dzmarc
  • 250 posts
Posted 19 November 2015 - 10:58 AM
Radweld could work, (although I have never had any luck) but I would consider if it is worth it.
Check the rest of the Rad to see if there is any missing fins etc, as this could be a sign of more damage and weak points.
If they look okay then Radweld may be a good option, but when you think of it as almost £10 delivered, its not a lot more for a brand new radiator (£50), at least then you would not have to worry about coolant loss.
Either way hope you get it sorted.
#3 GraemeC
GraemeC
  • 7,440 posts
Posted 19 November 2015 - 11:05 AM
K-seal is supposed to be better than rad weld and your local motor factors may stock it.  Either of these should only be a temporary solution (if they cure the leak) and replacing the radiator should be your priority.  After all - if it is corrosion that has caused the leak, chances are another hole will soon appear.
#4 Mon_Papillon
Mon_Papillon
  • 145 posts
  • Local Club: Norfolk??
Posted 19 November 2015 - 12:36 PM
Mini rads are cheap enough, get it changed :)
#5 stoneface
stoneface
  • 398 posts
Posted 19 November 2015 - 01:01 PM
If it's of copper/brass construction then solder it up, if you have the equipment.
If it's of plastic/aluminum construction buy a new one.
Radweld and the alike are not permanent fixes.
#6 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 19 November 2015 - 03:31 PM
I think brazing would be a better option than soldering.  Soldering should ideally be kept for electrical connections (although it's not much use in a car though due to the vibrations)
#7 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 19 November 2015 - 03:59 PM
You'll need to have it braised as they're copper.
Do NOT put rad weld, k-seal or any snake oil remedies into a cooling system. It's designed to activate on contact with water then set in contact with air. If you have any trapped air in the system it will create a clotted mess that will gum up your radiator, potentially causing over heating, or prematurely wear out your water pump. It is horrid stuff and I still have no idea what it's on the market still. A bit like t-cut.
#8 stoneface
stoneface
  • 398 posts
Posted 19 November 2015 - 04:09 PM
I used to solder them back in the good old days. Never had an issue.
Brazing requires far more heat which is likely to melt the rest of the radiator joints.
If you want to go one up on solder, use silver solder.
#9 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 19 November 2015 - 04:44 PM
K seal rad weld etc are aweful don't waste your money just get a new rad. Would even use an egg over those products atleast it's easy to get rid off. They get everywhere block everything up and are generally just garbage.
#10 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 19 November 2015 - 08:57 PM
Only one fix as far as I'm concerned, remove radiator, have repaired and cleaned out by authorised radiator repairer as they flow test and pressure test when completed or replace with new radiator. Additives are only a temporary repair and tend to clog up and block radiators and should never be used for a long term remedy.
#11 spiguy
spiguy
  • 1,537 posts
Posted 19 November 2015 - 10:08 PM
As above, don't put radweld or anything like that in. I used bar's leaks (which by the way is actually very good at what it does!) when my heater matrix started to leak. Only did it because I was skint. It did work, but then I laid the car up for a couple of years and it solidified in various places and made a right mess. Regretted doing it.  Just bite the bullet and renew the rad, or repair it / have it repaired. You'll  be glad  you did in the long run.
#12 Dusky
Dusky
  • 5,322 posts
Posted 19 November 2015 - 11:05 PM
I heard good things about jb weld, but it depends on how obvious and accessible the leak is ofc
#13 smurfomatic
smurfomatic
  • 461 posts
Posted 20 November 2015 - 10:17 AM
You could use JB Weld, but as it's a liquid you would need to drain the coolant system and allow it to set for 24hrs before refilling.
Another option is JB Waterweld - it's a putty-like substance that is supposed to set in wet conditions in about an hour. Once set it's rock hard and watertight - even works on fuel tanks as I found out during my major hassle with a leaking fuel sender...
