have been advised by jonspeed I can use the standard rocker posts
using 1.4 rocker bushes with a mg metro cam
whats your opinion
Posted 27 November 2015 - 04:59 PM
whats your opinion
Posted 27 November 2015 - 08:20 PM
Don't think so.
To get 1.4 ratio rockers the pivot point should be closer to the pushrods, and for this you need different rocker posts.
Even for offset bushes you really need different posts to get the rocker pads correctly centred over the valve stems and this is under 1.3 ratio.
So for 1.4 different posts should be essential, as without them the rocker pads may come too far across the valve stems.
