Budget Gear Box Syncro Rebuild Problem
11 replies to this topic
#1 hotwheels
hotwheels
  • 198 posts
Posted 02 December 2015 - 01:07 PM
2ncd gear grinded when downshifting from 3rd to 2ncd. Took the motor out, neatly disassembled the motor and tranny, then replaced 4 bulk syncro rinngs, put it back together catefully and the tranny seems hard to spin freely even in neutral, also i cannot get into 2ncd gear at all. Even When car is running or not, i havent drove the car yet due to crappy weather Every other gear works including reverse. Also when started in neutral the car feels like it wants to move forward the slightest bit. Weird. Mayb i put the gear box back together wrong. Any ideas
Thanks derek
#2 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 02 December 2015 - 08:35 PM
Is the clutch dragging a bit? Not disengaging properly?
#3 hotwheels
hotwheels
  • 198 posts
Posted 03 December 2015 - 01:28 PM
Found the issue hahah. The gear selection linkage with rubbing against a tab and pin https://flic.kr/p/BEMdpc
Unfortunately after replacing the syncroa. Down shifting from 3rd to 2ncd gear still grinds!!!!
Any ideas?? Do i need a new 2ncd gear?
#4 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 03 December 2015 - 03:25 PM
Could be that the 2nd gear synchro cone is badly worn. You should have checked that the baulk ring gripped the gear before assembly.
#5 Spider
  • 15,051 posts
Posted 03 December 2015 - 06:25 PM
Did you replace the Synchro Hub Springs at the time of the rebuild?
#6 hotwheels
hotwheels
  • 198 posts
Posted 04 December 2015 - 12:05 PM
The bulk ring on the hub before disassemble was approximately 1mm gap, with the new bulk ring theres a 3 mm gap and grips pretty good, it didnt look warn out. I just replced the rings that is it. But mayb it is the cone, idk what else it could be.
#7 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 04 December 2015 - 12:37 PM
Is the clutch definitely not still dragging?
#8 hotwheels
hotwheels
  • 198 posts
Posted 04 December 2015 - 01:04 PM
What do you mean by "dragging" im a little confused.
Its a verto clutch
Shifting UP 1sr gear through 4gear shifts perfectly
Shifting DOWN 4th gear to 3rd is smooth, 3rd to 2ncd grinds. 2ncd to 1st is smooth as well as reverse.
#9 hotwheels
hotwheels
  • 198 posts
Posted 04 December 2015 - 01:05 PM
I do have this one photo from inside the gear box after i installed the rings
https://flic.kr/p/ASstXo
#10 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 04 December 2015 - 06:52 PM
By dragging I mean that it does not fully disengage. You can usually tell when it is dragging when you shift to reverse, however you could check by getting the front wheels in the air - with the car in gear hold down the clutch and see if the wheels turn.
#11 hotwheels
hotwheels
  • 198 posts
Posted 04 December 2015 - 07:46 PM
Ok there is no dragging. The wheels do not turn when i push clutch in .
#12 gazza82
gazza82
  • 3,017 posts
  • Local Club: TMF+
Posted 04 December 2015 - 08:15 PM
I think you will find they should ...
