Using Filler On Fibreglass Parts
Posted 04 December 2015 - 01:02 PM
Now do I just rub the gel coat down so that it is dull and keyed then apply the filler or do I need to do something else ?
Posted 04 December 2015 - 01:07 PM
Posted 04 December 2015 - 01:13 PM
Posted 04 December 2015 - 02:11 PM
Nope, filler will bond mechanically the same, if not better. The issue is fibreglass is often more flexible. You can get gelcoat filler, but it's as tough as gelcoat to flat.
Cheers for the reply
Posted 04 December 2015 - 02:20 PM
I would use stopper rather than filler for slight skims over an edge, it's softer to flat and will be less likely to crack, key the gell coat and then skim and flat it off until it's how you want.
It's at the back edge of the bonnet that would be up against the scuttle. It's the strongest least flexible part of the bonnet and its most of the back edge. It's more that the join between the two parts is visible I will take a picture when I get home to show what I need to do
Posted 04 December 2015 - 08:57 PM
Posted 04 December 2015 - 11:15 PM
I'd be tempted to try some epoxy on a bit that small, but thick. Cheaper too, for a little tube of araldite.
just need something i can sand once its set can i do this and is it easy to over paint ?
Posted 04 December 2015 - 11:19 PM
But for those holes. Any will do. But make sure to key the surface and de grease it or it will not bond.
Posted 05 December 2015 - 08:45 AM
Back he first question. It is basically the same. But go for some speced as being flexible.
Thank you I will do that then as it only needs a little bit and I have loads of filler already
