Head Scratcher
Posted 04 December 2015 - 05:56 PM
I decided I'd change the head gasket to be on the safe side and have done that today although there was no real signs of a failure on the old one.
Any thoughts on this? Also I have imperial feeler gauges and the Haynes manual sys 0.33mm for the valve clearance. measuring the gauges with a micrometer I found 10 thou to be spot on but then when I remembered I had an older Haynes with imperial measurements I found it says 12 thou. Which is best?
JohnR
Posted 04 December 2015 - 06:01 PM
The mayo build-up can happen where car is used for shorter trips, and engine never really gets properly hot.
Also if crankcase ventilation is not working well this can promote mayo build-up.
Posted 04 December 2015 - 07:34 PM
as carbon say's , cold weather , short journeys will probably leave a bit of mayo in a few areas
give it a long run as a treat , will warm it up properly , the water vapour will have time to reduce in the crank / rocker areas as the temp increases
but the mayo may be still around , until the spring comes & temps rise
Posted 04 December 2015 - 10:36 PM
Posted 05 December 2015 - 10:24 AM
Posted 05 December 2015 - 02:05 PM
12 here
Posted 05 December 2015 - 04:41 PM
As Chopper says, 12 thou valve clearance with standard cam and rockers
Posted 05 December 2015 - 05:28 PM
12 thou, and mayo is normally down to water or condensation, short journeys are terrible, it needs a good run and check the breas are clear and the cap is good and air tight
Posted 05 December 2015 - 11:09 PM
JohnR
Posted 06 December 2015 - 05:17 PM
We are used to adjust the outlet valves a little higher than the inlet valves. E.g. Inlet valve 0,29 mm Outlet valve 0,32 mm
Dont you?
Posted 06 December 2015 - 05:30 PM
I use 12 thou inlet and exhaust, that's as recommended in workshop manual.
For high lift rockers you need to open up clearances, also some performance cams may differ slightly.
Posted 06 December 2015 - 09:35 PM
Dont you?
I used to run 12 thou on inlet & 15 thou on exhaust with modified heads / hotter cams
but now it seems everyone else runs 12 thou for both (unless different rocker ratio)
easier to do the valve lash that way 12 thou for all
Posted 06 December 2015 - 10:52 PM
I use 12 inlet, 15 exhaust personally (on a 1275)
Posted 06 December 2015 - 11:03 PM
Same!I use 12 inlet, 15 exhaust personally (on a 1275)
FS
Posted 08 December 2015 - 12:00 PM
As correctly stated above, mayo is due to condensation. Some people have cured it on various engines by thermally insulating the rocker cover, making a jacket from some suitable material.
But I noticed very many years ago that my old man's Vauxhall Viva, notorious for this problem, did generate a great deal of mayo when using Duckhams oil and very little when using Castrol XL.
Nowadays you would probably use Castrol GTX or some special "classic" oil, e.g. Millers, and that may do the trick. For various reasons, it is never worth using cheap oil, except in an engine and gearbox that are due for scrapping.
