Advice Please From Any Classic Car Restorer
Posted 07 December 2015 - 09:41 PM
Thanks in advance and sorry if this has already been covered here?
Sean.
Posted 07 December 2015 - 09:46 PM
Posted 07 December 2015 - 09:48 PM
Any areas to weld i use zinc rich primer and for anything else while i'm welding i use epoxy primer as its water resistant. Zinc primer is not.
Posted 07 December 2015 - 10:35 PM
As above, epoxy primer is the way forward .
Posted 07 December 2015 - 10:37 PM
Yep don't use rattle can etch primer, doesn't work. Get advice and supply from a pro shop on what's best to use. You don't have to ask on why I'm advising this route!!
Posted 07 December 2015 - 10:45 PM
Bilt Hamber Electrox zinc rich primer is waterproof. I'm using it on my resto but will still be overpainting it with epoxy mastics and primers.
Posted 07 December 2015 - 10:50 PM
Posted 07 December 2015 - 11:16 PM
Posted 08 December 2015 - 01:25 PM
this stuff does look good I'm going to call them for some more infoBilt Hamber Electrox zinc rich primer is waterproof. I'm using it on my resto but will still be overpainting it with epoxy mastics and primers.
Posted 08 December 2015 - 06:55 PM
But please don't use etch under epoxy as it's designed to grip fresh clean steel and it does this brilliantly
