Hi all, any recommendations for brushable seam sealer please
Brushable Seam Sealer
I hate Brian
, Dec 10 2015 10:02 AM
7 replies to this topic
Posted 10 December 2015 - 10:02 AM
Posted 10 December 2015 - 10:24 AM
I use the hb body pro fairly cheap and I've never had any problems but make sure you have primed the area first as this stuff goes on top
Posted 10 December 2015 - 10:57 AM
Hi thanks for the reply forgot to mention is it paintable ?
Posted 10 December 2015 - 11:18 AM
Yes its paintable just allow it to completely dry otherwise it will just go through the primer to the metalHi thanks for the reply forgot to mention is it paintable ?
I would use in a good day and not a moist/damp day unless you in a body shop
Posted 10 December 2015 - 11:43 AM
I find the tubes better used with a mastic gun, pu sealant from tool station is good and cheap, or if you want best use upol tiger seal
Posted 10 December 2015 - 12:04 PM
The HB pro body stuff is good and cheap make sure you etch first
Dave
Posted 10 December 2015 - 12:53 PM
Been using the cheap stuff on mine over primer and por15 works well difficult to get it smooth though so if your a perfectionist would suggest tubes other wise it's pretty good stuff,
Posted 11 December 2015 - 07:03 AM
thanks for all the replies lads
