I wonder if there are any sources outlining the brake efficiency of various set ups?
For example 8.42 discs with standard calipers vs 7.5" with 2 pot calipers?
Craig
Posted 10 December 2015 - 09:24 PM
Craig
Posted 10 December 2015 - 09:32 PM
Edited by Will16, 10 December 2015 - 09:47 PM.
Posted 10 December 2015 - 09:39 PM
Posted 10 December 2015 - 09:40 PM
Posted 10 December 2015 - 09:49 PM
Braking efficiency, assuming the brakes are in top condition, is not an issue until or unless the vehicle is driven right on the limit. Then the efficiency is dependant on brake size, tyre type & condition, pad composition/specification and brake fluid.
For example, driven very hard (and I do mean hard) a 7.5" brake with carbon-metallic pads will perform better than an 8.4" brake with standard pads or even Mintex 1144 pads.
From cold drum brakes will be as efficient as discs, but once the brakes heat up from hard use the drums will fade more easily.
This question is really for Minis in competition where the brakes will be operating at maximum temperature for a long period. On the road it is not really an issue.
Posted 10 December 2015 - 09:59 PM
The reason I am asking, is I am planning to modify /change my engine, to get the car legally registered with this modification, the info i have received is that i need to change the "whole" braking system to suit. concretely they have mentioned larger discs and new master cylinder.
I find myself in an unfortunate situation of having changed my standard 8.4 brakes to minisport 2 pot calipers and 7.5" discs. I was hoping to find data to suggest this was an improvement
Posted 10 December 2015 - 10:01 PM
Posted 10 December 2015 - 10:05 PM
Stop here and go back a step,
You are wanting to fit smaller wheels as well?
Already have.
Posted 10 December 2015 - 10:09 PM
Posted 10 December 2015 - 10:28 PM
Then I would be considering the 7.9 kit with 4 pots. If there is one.
No need to change the MC
Posted 10 December 2015 - 10:39 PM
OT I know, but I was chatting with a mate recently just on this and he more or less confirmed what I had been privately thinking for years.
On our Mokes (with 13" Wheels and a ~24" rolling dia wheel), Brakes have always been an issue as the bigger overall dia wheels have far more leverage over the brakes than what they were originally designed for.
Two things that came from our chat;-
Neither of us have ever been able to get the stock 8.4" Disc Set up to be able to lock on the front wheels. We have been able to get them to stop fairly good, but not to the point of locking. We have both tried all available pads on the market too. We both also agreed that they were better when warm but not hot or cold.
The same Mokes on Drum brakes can lock their front Brakes, but only when cold.
Edited by Moke Spider, 10 December 2015 - 10:40 PM.
Posted 10 December 2015 - 10:41 PM
Posted 10 December 2015 - 10:45 PM
Posted 10 December 2015 - 10:56 PM
Don't know about calculations but from experience of sudden braking, I have found my 7.5" setup from minispares to be excellent. I recently had to brake emergency style when a sheep ran out on the road in front of me. I was doing over 50 mph and stood on the brakes, on a wet road with Yoko A008's, and to be honest I really didn't think I would stop in time, as it was the car drew up perfectly, and very quickly too. Much better than I expected. I certainly think that the smaller disc brakes are more than up to the job on a mini.
Posted 10 December 2015 - 11:00 PM
I have just looked out my old MOT certificates. they show the brake efficiency in KN
Results on 8.4" discs standard caliper: year 1 - left 1.4 / right 1.4
year 2 - left 1.2 / right 1.3
Results on the 7.5" discs, 4 pot calipers: year 1 - left 1.6 / right 1.6
Not sure how rigorous this is in terms of proof of improved efficiency
