Wheel Cylinder 99023C Replacement Part Number - Help
7 replies to this topic
#1 ryomini
ryomini
  • 583 posts
Posted 13 December 2015 - 07:51 AM
Hallo allo
my wheel cylinders are TOTALLY seized, pistons cannot even be removed so I am having to replace them
the marking on the casing is 99023C and as there seem to be a fat lot of different models I don't want to order the wrong 'uns
is there a TMF member who knows the correct part number for this item and or it's replacement / updated part - a big thanks if you can 'elp
cheers
#2 Spider
  • 14,942 posts
Posted 13 December 2015 - 08:06 AM
What year and model is your Mini?
#3 Daz1968
Daz1968
  • 2,058 posts
Posted 13 December 2015 - 08:14 AM
That's probably a cast number so not really enough information. As above year and type of car will help as there are a number of different bore cylinders available.
#4 ryomini
ryomini
  • 583 posts
Posted 13 December 2015 - 02:56 PM
Mini is Jap spec 1993 spi 1.3injection (injection model with coil)
and on my local factors web site they only have 19mm 3/4 inch bore cylinders available
sorry to be noobie but the 'bore' refers to piston size ? as the od of the brake line fitting on the casing is exactly 17.5mm 11/16
what the piston bore is I cannot measure as they are totally seized in
thanks for your help
#5 tiger99
tiger99
  • 8,584 posts
Posted 13 December 2015 - 05:14 PM
This link may help:
http://www.somerford...page=page&id=60
It looks as if all later models, including yours, were 3/4" bore. Presumably you have the PRV (pressure regulating valve) under the bonnet? The cast iron thing, mounted below the master cylinder on the bulkhead, where the brake lines go, before heading towards the front and rear brakes.
If not, 3/4" would be incorrect.
And yes, the 3/4" bore size is, for practical purposes, the same as piston diameter. (There is a very small clearance to allow movement, probably no more than 0.001").
Edited by tiger99, 13 December 2015 - 05:16 PM.
#6 ryomini
ryomini
  • 583 posts
Posted 13 December 2015 - 11:27 PM
Ugh
piston bore is 19mm so 3/4 measured the bit that sticks out with the slot in it (rear wheel cylinder by the way) so I guess they are standard
will pick up a pair asap
thanks for helping
#7 cal844
cal844
  • 9,625 posts
  • Local Club: TFMOC
Posted 14 December 2015 - 10:49 AM
Id also change the retaining clip on the back plate
#8 ryomini
ryomini
  • 583 posts
Posted 19 December 2015 - 08:35 AM
Thanks guys
new one's came with a clip and a nice little gasket
