Guys,
Just swapped out a rear subframe for a replacement unit. Now at the stage of reattaching the radius arms, and one side has gone on ok (with some wrangling). Now I am having some real issues getting the second side on. The bracket for holding the outer end of the radius arm to the subframe simply will not line up, as if the arm is too long to attach to the subframe mount points.
We have tried torquing the ends tight to the arm, and trying to wriggle the holes to align with the nuts slack, but nothing is working for us.
Any suggestions as to what might be going wrong?
