Hi Everyone,
I recently got myself a Moke. It currently has a different wheel fitted but came with the original needing refurbishing. This is a job I would like to tackle myself and wonder what advice people have?
Regards
Peter
Posted 20 December 2015 - 08:39 PM
Posted 21 December 2015 - 06:30 AM
Yeah this is the plan for my one as well was going to rub it down and repair the cracks, some black paint with some coats of clear as well.
Posted 23 December 2015 - 11:59 AM
I rubbed mine down and painted it and then used a few coats of clear
Thanks, sounds easy enough. Just a black spray can to paint?
Posted 24 December 2015 - 11:51 PM
Maybe black epoxy paint, which should be hard wearing? I think ordinary paint will have a very short life.
Posted 26 December 2015 - 06:29 AM
It might also be an idea to plastic weld the cracks rather than use polyester filler, as with the flex in a steering wheel you will most likely see the cracks re-appear after a short time. Or if you dont know what plastic it is or have any spare to weld with you can use araldite to fill and repair the cracks, this will "move" enough with the rest of the wheel to not re-crack. And if you are painting from a gun, add a flex-aid to the paint to allow a little give, if painting from a can i would use plastic paint for bumpers etc.
Andy
Posted 26 December 2015 - 09:59 AM
same here!!!!!!!!
clean down with thinners quickly
wipe dry
light sand with 500 s
blow off
fill the little cracks
sand with 500s again till smooth
use satin black u pol paint in a can cheap doesnt react with much drys quickly.
build up in thin layers, dont rush, when totally covered use clear lacquer,
the results will amaze u.
