Soft Paint
Posted 21 December 2015 - 08:35 PM
Posted 21 December 2015 - 08:37 PM
after two weeks it should be solid no matter what
Posted 21 December 2015 - 08:49 PM
Stone chip should never go Hard. It's the soft rubbery finish that stops the stones from chipping.
If it went rock hard, then it would be susceptible to chips.
How soft is it?
Posted 21 December 2015 - 08:58 PM
Posted 21 December 2015 - 09:07 PM
Hi ben it was rock hard before i applied the top coat and the paint appears to have dried but if i push my nail into it it will leave a mark.i used gravitex stonechip
It's probably the solvents in the top coat have softened everything up. If it was a reaction, then you would expect to see pickling.
I would wait and see for now. It could take weeks for the solvents to fully evaporate and the paint harden
Posted 21 December 2015 - 09:11 PM
Did you put the correct amount of activator in the 2K top coat ??
Posted 21 December 2015 - 09:13 PM
trog
Posted 21 December 2015 - 09:14 PM
Posted 21 December 2015 - 09:15 PM
hi there i used the same gravitex stonechip brilliant stuff provides a nice base, i then used 2k on mine and it dried fine, i have heard a few horror stories from a few pro sprayers who knew people that had mixed the brands of paint/hardener, by and chance was it a u pol hardener?
Posted 21 December 2015 - 09:18 PM
sounds correct . I had this happen once and it must of been faulty activator or paint ?? , i left it for about 2 weeks and it still never went off fully . right pain in the arse as i had to strip it all back off again
As Matty said . some done mix well
Edited by STG95F, 21 December 2015 - 09:19 PM.
Posted 21 December 2015 - 09:19 PM
Posted 21 December 2015 - 09:25 PM
mix some more up and try on a small section of spare steel without the stone chip and see if that goes off fully . then you will know if it the stone chip at fault
Posted 21 December 2015 - 09:30 PM
well the 2k paint i used was the churchhill stuff had upol hardener all mixed correct, once the paint had cured i was then able to literally peel every bit of paint off back down to the primer, i had give it a good key as i did before primer, even the bodyshop said it was soulely down to mixing the brands bloody annoying when the paint was supplied as part of a kit :@ but hey ho!
Posted 21 December 2015 - 09:51 PM
Had this before!
Posted 21 December 2015 - 09:53 PM
