Block To Gearbox 5/16 Bolts
20 replies to this topic
#1 bluemini1979
bluemini1979
  • 619 posts
  • Local Club: Colchester Mini Club
Posted 29 December 2015 - 10:07 PM
When redrilling the block and gearbox to take 5/16 unf bolts is there a kit of the bolts and washers available. if not what bolts do people use?
thanks
#2 Ivor Badger
Ivor Badger
  • 846 posts
Posted 29 December 2015 - 10:16 PM
You have to use cap screws in many of the holes, especially the front. There is not enough clearance for hex heads. Makes it a real pain getting the in and out, but if needs must.
#3 Cooperman
  • 23,327 posts
Posted 29 December 2015 - 10:24 PM
Why would you go to the trouble of doing this?
Most really modified and ultra high-revving Minis don't have this done and have no gearbox to block interface problems.
#4 bluemini1979
bluemini1979
  • 619 posts
Posted 29 December 2015 - 10:28 PM
It was suggested and was looking into it before committing
#5 tiger99
tiger99
  • 8,584 posts
Posted 29 December 2015 - 10:29 PM
The only reason I can imagine is stripped threads, which are best repaired by fitting helicoils.
#6 Spider
  • 15,160 posts
Posted 29 December 2015 - 11:53 PM
It's really not at all needed.
#7 The Principal
The Principal
  • 763 posts
Posted 30 December 2015 - 06:22 AM
This may help -
http://www.minispeed...-516-allen-cap/
http://www.theminifo...e-bolts-to-516/
#8 Ethel
  • 26,088 posts
Posted 30 December 2015 - 11:45 AM
It's in the Vizard 'bible'as a mod to counter leaks from block flexure. I reckon you'd have more to worry about if you put that much stress on you engine.
#9 Cooperman
  • 23,327 posts
Posted 30 December 2015 - 02:50 PM
Maybe it applies to engines revving at 7500 rpm+.
I've never had any problems with engines that rev to 7000.
A better mod might be to Heli-Coil all the holes at 1/4" UNF and use higher-tensile steel bolts with, say, 20% increase in torque figure.
I still think it's unnecessary and a lot of work for nowt.
#10 Dusky
Dusky
  • 5,322 posts
Posted 30 December 2015 - 02:52 PM
My dads track mini has no problems with oil leaks. Rev limit set at 8.5k.
Standard fixing
Edited by Dusky, 30 December 2015 - 02:52 PM.
#11 Ethel
  • 26,088 posts
Posted 30 December 2015 - 03:21 PM
I can't remember if it was just a pre A+ thing. Certainly more for stroked cranks and very high revs. I recall we had a rather techie topic on it once that pointed the finger at the centre main bearing web. I think I'd be inclined to reach for the RTV Silicone and torque it up in two phases if I was concerned.
#12 mad mk1
mad mk1
  • 746 posts
  • Local Club: TurboMinis.co.uk
I don't think there is any need,
I just make sure the gearbox face is nice, I use 1/4 bolts all round.
Never had a leak with my 200+ Bhp and Rev it to 8k on the strip.
Just get some 12.5 cap head bolts.
#13 bluemini1979
bluemini1979
  • 619 posts
Posted 30 December 2015 - 06:02 PM
Thanks. I won't be spending my time doing it then. Only wondered as It had been suggested and its in the vizard book. Spend my time polishing the shell instead then :D
#14 Spider
  • 15,160 posts
Posted 30 December 2015 - 06:36 PM
I have great admiration for David, but on this, his advice is incorrect.
<Edit: If I recall, it was in his first book 'How to Modify Your Mini', but wasn't in his later books>
Edited by Moke Spider, 30 December 2015 - 06:37 PM.
#15 1968andyf
1968andyf
  • 144 posts
Posted 30 December 2015 - 06:45 PM
Could vizard have meant as a mod for the thin flange early s blocks
