Injector Cleaner. Yay Or Nay?
Posted 01 January 2016 - 08:41 PM
My 1.4 lupo is coming up for an extraordinarily over due service. A friend of mine keeps telling me to use some 'injector cleaner' in my next full tank of fuel to help with emissions and better running etc.
In my experience, i've used it once on an N reg corsa, helped for about 2 weeks then was worse than before.
So whats everyones take on this kind of thing?
I know octane boosters and the like are pretty pointless.
Rob
Posted 01 January 2016 - 09:02 PM
Use Forte products. We use them in work. I don't believe in using all these 'treatments' ect. I think a good long run on the motorway would be for more beneficial. My mum always told me I was a 'Victor'.
Edited by Anthony30, 01 January 2016 - 09:08 PM.
Posted 01 January 2016 - 09:15 PM
Back to the injector cleaners. A good heavy does and use for a length of time can help.
Results can and do differ.
Posted 01 January 2016 - 10:01 PM
I would change fuel filter as well , if that hasn't been done in the service ?
(solvents in the Injector cleaner can loosen up gum , residue & dirt etc , caught in the filter)
I mix it with a bit of petrol & put it in 1/4 full tank
go for a brisk drive
Posted 01 January 2016 - 10:15 PM
Posted 01 January 2016 - 11:45 PM
Posted 01 January 2016 - 11:52 PM
Posted 02 January 2016 - 03:22 PM
only use engine flush if it is easy to get the sump off
the gunk it loosens can block the strainer & drain holes back from the head
especially on a vee engine
did a rebuild on a v6 granada taxi in the 80's , driver did an engine clean / flush (first after years of abuse)
all the oil stayed in the head / vee - none in the sump - flakes of tar / gunk blocked drain holes
blew the ends / cooked the mains
wasn't pretty , but the tar was loosened from the engine
needed a full rebuild
Edited by sledgehammer, 02 January 2016 - 03:23 PM.
Posted 02 January 2016 - 04:01 PM
I had the same thing with a Mercedes 280 SE in the early 1990's. It had done over 22000 since an oil change and the owner asked me to help him. He bought new oil and an engine flush oil. After draining off, filling with flushing oil and finally filling with top quality synthetic it seemed fine, but ran all the big ends a few days later.
I don't like these longlife oils. The service interval on my BMW 730D is 20000 using LL-04 0w30 or 5w30 oil. I change mine every 7000 to 8000 and I use a 5w40 fully synthetic LL-04 (Castrol Edge - b****y expensive, but good) which seems fine. I use a full bottle of injector cleaner every 3000 miles.
Posted 02 January 2016 - 04:29 PM
off subject - but years ago had a maestro for sales service - 1.3l with the long filler neck
warm up engine - very tappetey undone sump bung - nothing
poked a bar in , some water / sludge came out
stripped it - was covered in greasy sludge & ends / pump / mains were shot
found in the spare wheel well - winns oil additive
Posted 02 January 2016 - 05:07 PM
Or think of it this way, would you buy a 60k bmw that's only ever had (if at all) 2 oil changes in its life?
Going back a decade of so, think of all the mpis with stuffed gearboxes because of the thinner oil (better for the emissions and cat) and increased oil changes from 3k to 12k.
But then laziness and maintenance free helps sell things, why bother servicing something as often or looking after when it's 'cheaper' to just throw it away and buy another.
Posted 02 January 2016 - 05:27 PM
It seems to be BMW, Mercedes and Audi trying to outdo each other on the length of service intervals. There will not be any problems within the warranty period so they don't care.
Maybe I'm old school, but to me engine life is directly related to regular oil changes at less than 10000 miles between changes.
I had a 1987 BMW 728i which I ran round from 50000 miles to 247000 miles without any real problems. I did a precautionary oil pump and bottom end bearing change without removing the engine at 185000 and when I sold it there were no engine issues - it was the electrics/electronics which were starting to fail. I changed the oil every 6000 miles using 5w40 oil. That was without doubt the best car I ever owned.
