Anyone got a Spotwelder...
14 replies to this topic
#1 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 16 August 2006 - 08:30 PM
Helloooo...
Cheeky post really, I am doing my sills soon, and as their brand new, oridgal sills, I in the understanding, I can spotweld these :D
I was wondering, as my mig welding isn't the smoooooothest.... :o can anyone lend me a spot welder?
I don't need it yet... in a couple of weeks I will thou... Don't mind paying for the use either :w00t:
#2 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 16 August 2006 - 09:43 PM
drill holes in the sill and weld thru the holes. This is known as plug welding andwould have the same effect as spot welding.
#3 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 16 August 2006 - 09:46 PM
MOT passable like that?
I am right in thinking, as I am replacing panels to orginal spec... I can spot weld right?
#4 minisprint
minisprint
  • 1,036 posts
  • Local Club: GR8 minis
Posted 16 August 2006 - 09:53 PM
yes allowed to spot weld original panels on just bare in mind how many spot welds are on the panel you are replacing and try to replicate as best as possible
#5 dougie_10 :D
dougie_10 :D
  • 447 posts
  • Local Club: The Mini Forum
Posted 16 August 2006 - 09:57 PM
My dad is a pro welder and reckons that plug welding in some cases is stronger than spot welds .When replacing my seals though he stitch welded it however . :D
#6 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 16 August 2006 - 09:59 PM
what's stitch welding doug?
#7 dougie_10 :D
dougie_10 :D
  • 447 posts
Posted 16 August 2006 - 10:06 PM
Basically i think from what my dad tells me it is were the two panels join a "stitch" line is welded in different parts with gaps in between the welds along the panel joins. Its difficult to explain but the panel sort of look a bit like this:-
The gaps between the dashes being the gaps in the panels. Obviously to make the rust proof you can use seam sealer to fill these gaps.
#8 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 16 August 2006 - 10:17 PM
I know what you mean...
it was done to the sills I took off my Mini.... they fell off!! either C**p welding or worse....
#9 dougie_10 :D
dougie_10 :D
  • 447 posts
Posted 16 August 2006 - 10:24 PM
Yer lol
Most probably craply done as lots of people cheat by only doing one side of the panel were for the most effective way you should if possible do a zig zag pattern if you see what I mean :D
so it would look something like this either side of the panel
- - - - - - weld
------------ panel
- - - - - -weld
Also this method is meant to be stronger than spot etc . My dad sometimes uses this method when welding plates etc to major rsj's and in 18 years has never ever had a complaint.
Edited by dougie_10 :D, 16 August 2006 - 10:26 PM.
#10 1984mini25
1984mini25
  • 8,785 posts
Posted 17 August 2006 - 06:57 PM
Wouldn’t bother with a spot welder, would be easer to drill a hole and weld thru.
#11 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 17 August 2006 - 07:53 PM
Then I got to grind the welds flat :doze:
#12 steveobennet
steveobennet
  • 944 posts
  • Local Club: stu's turbo club
Posted 17 August 2006 - 08:11 PM
certianly have got the motivation at the mo have ye? i can see the convience of spot welding, but if you already have a mig welder why not plug!
#13 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 17 August 2006 - 08:17 PM
Its got to be done...
I've asked for a magic pixie to come and do it, but no one turned up :D
So I've knuckled down, and I just to get it done! I'd prefure to spot weld the sills, as its just going to look a whole lot neater!
#14 TWICEmonkey
TWICEmonkey
  • 1,150 posts
  • Local Club: A-Serious.com & TMF
Posted 17 August 2006 - 08:28 PM
- - - - - - weld
------------ panel
- - - - - -weld
Ain't that seam-welding?
The same was done to our Mk3 Fiesta shell at college before we welded in the rollcage.
#15 dougie_10 :D
dougie_10 :D
  • 447 posts
Posted 17 August 2006 - 08:56 PM
- - - - - - weld
------------ panel
- - - - - -weld
Its hard to explain mate. I will explain if you come down or whatever if you ever need welding done and dont want to do it yourself :D
