Clutch Return Spring
11 replies to this topic
#1 pusb
pusb
  • 1,216 posts
Posted 09 January 2016 - 01:28 PM
Should both the verto and pre-verto type clutches have a return spring on top of the lever arm? Mine seems to be missing.
I'm not sure if mine is a verto or pre-verto, its a 1979 850 engine.
I sometimes get a burning clutch smell on long journeys, and a slight judder when pulling off in 1st, so could that be caused by the missing spring?
#2 nicklouse
  • 18,701 posts
Posted 09 January 2016 - 01:34 PM
Verto don't have a spring.
Verto short arm slave on wok.
Pre verto long arm slave on transfer case.
#3 pusb
pusb
  • 1,216 posts
Posted 09 January 2016 - 02:04 PM
How can I tell what type I have?
#4 steeley
steeley
  • Just Joined
  • 623 posts
Posted 09 January 2016 - 03:13 PM
Look on googles images you should be able to spot the difference that's what I do when I'm not sure
#5 nicklouse
  • 18,701 posts
Posted 09 January 2016 - 06:04 PM
Where is the Slave?
#6 pusb
pusb
  • 1,216 posts
Posted 09 January 2016 - 06:16 PM
Towards t
Where is the Slave?
Towards the back, not my car, but I found this picture on google. Slave is in same place on this as it is on mine:
Attached File  clutch.jpg   68.93K   13 downloads
#7 Spider
  • 15,154 posts
Posted 09 January 2016 - 06:37 PM
Pre-Verto and it should have a Spring, though that won't be the cause of the burning smell.
<Edit: When you get this smell next time, see if the clutch is slipping. Easist way to do that is while driving in 3rd or 4th gear, just easy the clutch pedal down a little and slowly, don't lift the throttle, as soon as you hear the engine revs rise, 'drop' the clutch (ie, get your foot off it as rapidly as you can), you should hear the engine revs drop sharply and suddenly to match the cars road speed. If the revs slowly come down, then the clutch is slipping. >
Edited by Moke Spider, 09 January 2016 - 06:40 PM.
#8 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 09 January 2016 - 08:45 PM
To test a clutch all I do is fire the car up and try to pull away with the hand brake on... The car should cut out if the clutch is ok, if the engine stays running and your foot is off the clutch its time to check the adjustments and then repeat the above, does the motor die or can your foot be lifted off the pedal?
#9 tiger99
tiger99
  • 8,584 posts
Posted 09 January 2016 - 09:00 PM
No-one has yet answered the first question. The Verto must not have an external spring, and the pre-Verto must have the external tension spring between the lever and a tag on the slave cylinder.
See here:
http://www.somerford...age=page&id=144
#10 pusb
pusb
  • 1,216 posts
Posted 10 January 2016 - 09:50 PM
So mine should definitely have the spring. I will have to order one.
Moke & Cal, I have tested it before when it was smelling, and I really couldn't get it to slip. Engine died if I left the h/brake on, and if I try that trick of seeing how quickly the revs drop, they drop straight away.
#11 Spider
  • 15,154 posts
Posted 11 January 2016 - 12:15 AM
Pusb, are you able to describe the smell at all?  Does it smell like Train Brakes or Oil or ????
Hey?
Pre-Verto and it should have a Spring,,,,,,,
#12 pusb
pusb
  • 1,216 posts
Posted 11 January 2016 - 06:18 AM
Hey?
It only does it when driving fast. The nearest thing I can describe the smell to is a hot water bottle! A sort of hot rubber smell.
Edited by pusb, 11 January 2016 - 06:19 AM.
