Getting A Mini On A Trailer Without Front Subframe
9 replies to this topic
#1 Chris1992
Chris1992
  • 2,022 posts
Posted 12 January 2016 - 12:02 PM
Hi guys, so the time has come this weekend to ship my mini off for paint. I have a trailer organised, but one thing I'm a little worried about is actually getting the car onto it. currently the car is a bare shell up on axle stands and has no front subframe fitted, but the rear one still is. So, I know that I can simply put wheels on the rear of the car, and I do have a trolly to put under the floor pan to move it around, but I dont think that will actually help me get it on the trailer.
Anyone else been through this before? What did you do? do i simply lift the car at the front and pull in onto the trailer? Where are the safe points that I can lift from without causing damage?
#2 Cooperman
  • 23,366 posts
Posted 12 January 2016 - 12:21 PM
If the wheels are on the back you can put it on backwards and push it up the ramps with a bit of help.
Then put a couple of blocks under the front of the body and strap it down. It is surprising how light the front is with no frame or engine fitted. Lift it at each side of the front panel and under the wheel arches. It won't bend so long as you are careful. I reckon maybe 3 people to do this, although I've done it with just two in the past, one each side of the front panel.
#3 acrowot
acrowot
  • 278 posts
  • Local Club: manchester minis
Posted 12 January 2016 - 01:10 PM
id be more worried about getting it off after its been painted ive got them on before on my own backwards with a trolley jack then just lifted it for last bit
#4 nicklouse
  • 18,751 posts
Posted 12 January 2016 - 01:24 PM
I would lose the rear frame as well and get some mates around and just put it on the trailer.
#5 newenglandmini
newenglandmini
  • 646 posts
Posted 12 January 2016 - 01:49 PM
This is my car returning from paint a few months ago.  I built a trolley using 2X4 lumber and casters.  I used a come-along to haul it up my trailer ramp, whilst my wife and neighbor guided the load from either side.  The trolley also facilitated movement of the car whilst at the paint shop.  I still have the car on the trolley to facilitate reassembly and needed movement in my shop.
Attached File  PICT0015.JPG   109.18K   6 downloads
Attached File  PICT0016.JPG   96.08K   5 downloads
Attached File  PICT0017.JPG   105.72K   5 downloads
Attached File  PICT0021.JPG   61.12K   7 downloads
#6 Chris1992
Chris1992
  • 2,022 posts
Posted 12 January 2016 - 07:15 PM
some good suggestions here! thanks very much chaps!
#7 rhys-89
rhys-89
  • 1,549 posts
  • Local Club: minifreekz
Posted 12 January 2016 - 07:23 PM
If your feeling strong when I moved my Mk1 shell two of use picked it up and walked the shell on the trailer
#8 newenglandmini
newenglandmini
  • 646 posts
Posted 12 January 2016 - 07:29 PM
I've picked up mine with one other chap as well.  The paint shop staff probably won't be happy with that approach however.
#9 mattmiglia
mattmiglia
  • 515 posts
Posted 12 January 2016 - 07:46 PM
I've carried a shell with me and 1 other before or screw some castors to a pallet and push it on :)
#10 bpirie1000
bpirie1000
  • Area Managers
  • 2,448 posts
  • Local Club: Amoc
Posted 12 January 2016 - 08:19 PM
Pallet and casters was my way..
Annoying with fresh paint all pretty....
