Mk1 Front Panel (Valance)
10 replies to this topic
#1 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 13 January 2016 - 05:05 PM
Hi all I was wondering if any of you guys would no the answer. I have a June 1964 Austin mini 850 that I will get round to starting one day however I was wondering which front panel it should have I am really hoping that the full skirt front panel would be correct.
Am I right in thinking that the full skirt front panel didn't change until Sep 64 so mine would have had one fitted originally?
Cheers Guys
#2 lancs-lad
lancs-lad
  • 42 posts
Posted 13 January 2016 - 05:22 PM
Wiki says July 1964
#3 minimissions
minimissions
  • 3,427 posts
Posted 13 January 2016 - 09:46 PM
Cheers yeah this is what I found so I am just in the right part of the year for a full skirt front :) yay!!!!!!
#4 midridge2
midridge2
  • 1,794 posts
Posted 14 January 2016 - 06:25 AM
I don't think they make the full skirt front panel now you would have to buy the  end pieces and weld them in.
#5 minimissions
minimissions
  • 3,427 posts
Posted 14 January 2016 - 06:33 AM
Think m-machine make it I have seen a few people on here get them for their projects :)
#6 Daz1968
Daz1968
  • 2,058 posts
Posted 14 January 2016 - 08:35 AM
Yes m machine sell a reworked panel to mk1 spec, only thing is the indicator plinths are incorrect but they also sell these if you want to weld them in to make correct, if you don't mind the work they also sell the end pieces to convert a standard panel to full skirt which is what I did, there is other things that need changing but nothing too difficult.
#7 minimissions
minimissions
  • 3,427 posts
Posted 14 January 2016 - 02:11 PM
Yeah thought this was the case as well how different is the early indicator area ? is it really noticeable?
#8 Daz1968
Daz1968
  • 2,058 posts
Posted 14 January 2016 - 05:48 PM
The correct indicator plinth is size of early glass indicator whereas later one suits the plastic ones, it is larger in diameter so when you fit the correct early indicator there is a flat area around it, I never changed ones on my mk1 but will do on my current mk2 project. Depends how fussy you are really as most don't notice this
Edited by Daz1968, 14 January 2016 - 09:19 PM.
#9 minimissions
minimissions
  • 3,427 posts
Posted 14 January 2016 - 08:42 PM
The correct indicator plinth is size do early glass indicator whereas later one suits the plastic ones, it is larger in diameter so when you fit the correct early indicator there is a flat area around it, I never changed ones on my mk1 but will do on my current mk2 project. Depends how fussy you are really as most don't notice this
Ok thanks just had a quick look through some builds and I see what you mean, cheers daz :) will have a think and see if I will do this...
#10 Daz1968
Daz1968
  • 2,058 posts
Posted 14 January 2016 - 09:18 PM
Think they are about £8 each, will do them on my mk2 as not difficult to do.
#11 minimissions
minimissions
  • 3,427 posts
Posted 18 January 2016 - 06:35 AM
Ok cool thanks I will have a look through some builds and have a look..
