1275 Spi Or Convert To Twin Carb ?
Posted 15 January 2016 - 07:31 AM
Posted 15 January 2016 - 08:11 AM
I started a thread about converting from SPi to carb and a few said to fix the SPi..... I'll be on mine today hopefully once Iv done a bit of housework...
Posted 15 January 2016 - 09:05 AM
Fix it in my opinion, but plenty of people have converted
How's the service condition of your car? Vac pipes in nothing short of perfect condition?
Check all the sensors and connectorsa te all good, check you loom and earth points
Posted 15 January 2016 - 09:33 AM
I'd say fix it, although in some cases is far easier to convert to carbs, it will devalue the car and give issues at the MOT
Posted 15 January 2016 - 10:11 AM
Posted 15 January 2016 - 10:24 AM
The fact that it starts and runs means that the alarm/immobilser is working or has been bypassed, either way not what's causing your current issue.
Definitely start with a good service, including valve clearance and fuel filter.
Do you have access to a code reader?
Edited by Fast Ivan, 15 January 2016 - 11:44 AM.
Posted 15 January 2016 - 10:48 AM
Could be a dodgy fuel pump
The fact that it starts and runs means that the alarm/immobilser is working or has been bypassed, either way not what's causingy our current issue.
+1 also change all vacuum lines including fuel trap
Posted 15 January 2016 - 12:22 PM
Posted 15 January 2016 - 01:39 PM
Posted 15 January 2016 - 02:11 PM
Posted 15 January 2016 - 03:24 PM
There should be a round connector in the engine bay, usually protected by a rubber cover, thats where you plug the reader
Have to look for a picture
Posted 15 January 2016 - 03:42 PM
Stragely havent got a pic, anyway if you scroll this thread:
http://www.theminifo...oint-injection/
You'll find a picture showing a green connector for the alarm reader, now (you dont see in the pic-have a look at your car) if you look closer to the brake master cylinder there will be a similar plug in white hanging there.
Posted 15 January 2016 - 04:50 PM
