Argyle Deg's 1380Cc Mini In Surrey.
3 replies to this topic
#1 Argyle Deg
Argyle Deg
    Just On Tickover
  • 8 posts
Posted 15 January 2016 - 06:34 PM
I have been rebuilding a Mini here in Surrey for the past year or so and I am coming close to completion.  The car has been previously owned by other enthusiasts and arrived by trailer to my home in an incomplete state.  I have re-registered the car which is a 71 model that now has a whole range of expensive new components.
I would like to make contact with other informed Mini owners and enthusiasts in order that I might discuss technical issues and chew on problems I have.  I am elderly but sprightly and have worked on sporty cars for many years.  I look forward to future discussions.
#2 cal844
cal844
  • 9,646 posts
  • Local Club: TFMOC
Posted 15 January 2016 - 06:45 PM
Welcome yo the mad house!
Post your issues in the Mini technical section
Also if you upload images to photo bucket you can post up some pictures in case it will help with any queries
Look forward to trying to help you in some way
#3 Argyle Deg
Argyle Deg
    Just On Tickover
  • 8 posts
Posted 29 January 2016 - 06:39 PM
I now have a problem trying to bleed the clutch,  I fitted a new master cylinder. I fitted new rubbers in the slave.  I fitted a new up-rated clutch arm.  Fluid will not even run from the master cylinder to the slave cylinder by gravity when the nipple is open.  Don'r usually have such problems.  Any ideas chaps pl?
#4 James_eaton_thewholething
  • 1,063 posts
Posted 04 February 2016 - 12:33 AM
Pressure bleed the system with something like an easy bleed. The clutch also isn't like brakes as the pipe comes out the top so in theory the resvevoir isn't the highest point.
Edited by James_eaton_thewholething, 04 February 2016 - 12:39 AM.
