A Series Con Rod Lock Tabs, Re-Use?
10 replies to this topic
#1 blacktulip
blacktulip
  • 6,224 posts
Posted 18 January 2016 - 02:41 PM
is it ok to re use the con rod cap lock tabs?
#2 GraemeC
GraemeC
  • 7,440 posts
Posted 18 January 2016 - 03:08 PM
I wouldn't advise it - they will work harden and eventually the ears will snap off.  You might not be the first to reuse them!
At £1 a piece they're not worth the worry.
#3 jaydee
jaydee
  • 8,565 posts
Posted 18 January 2016 - 03:57 PM
Honestly i wouldnt use them at all
I'd just use quality bolts without those soft tabs
Edited by jaydee, 18 January 2016 - 03:57 PM.
#4 Swift_General
Swift_General
  • 871 posts
Posted 18 January 2016 - 04:29 PM
As above I wouldn't use a lock tab at all. If they are soft and of poor quality then some of the clamping force is reduced which could be a problem. Just use decent bolts (and I don't necessarily mean pricey ARP ones) correctly torqued up.
Edited by Swift_General, 18 January 2016 - 04:31 PM.
#5 Spider
  • 15,144 posts
Posted 18 January 2016 - 05:27 PM
In line with the other guys, I haven't used any lock-tabs, not just Big End one, none of them, for many years, the new ones are too soft and ooze out over time.
The Mains and Big Ends I Oil the Fasteners on the Threads and under the heads, then only torque up to the relevant figures. Of course, the Spot Facings have to be good too, otherwise the fasteners will loose stretch and come loose.
The Camshaft Nut, Harmonic Damper, Flywheel, Pinion Nut, Pinion Bearing Carrie Bolts and First Motion Shaft Nut I use Loctite on.
#6 Dusky
Dusky
  • 5,322 posts
Posted 18 January 2016 - 05:33 PM
I always use loctite after my flywheel pressure plate and center bolt comming loose..
#7 blacktulip
blacktulip
  • 6,224 posts
Posted 19 January 2016 - 12:05 PM
should i use loctite on them as a precaution? i have done them up already now. is it ok to undo them again?
#8 jaydee
jaydee
  • 8,565 posts
Posted 19 January 2016 - 01:40 PM
Not on big end neither on mains
Essential on other fasteners ie anything clutch related
#9 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 19 January 2016 - 02:25 PM
The only thing you should be using on mains and big end bolts/threads is moly lube. You'll get a more accurate torque measurement when tightening.
#10 Spider
  • 15,144 posts
Posted 19 January 2016 - 06:23 PM
You can for sure, but IMO on street use cars, Mains and Big Ends, I wouldn't bother.
#11 blacktulip
blacktulip
  • 6,224 posts
Posted 19 January 2016 - 06:28 PM
Cool thanks
