http://www.minispare...C-22A1737A.aspx
The inner bearing surface is shot at one end but it can be drilled and reamed out to suit A+ box with bigger bearing.
Saab t2 inlet pipe, blasted and painted. £10
Down pipe £5
Wilwood remote res kit missing cap £8
Front plate £20
Full roller rockers 1:5:1 some marks and trimmed to fit under rocket cover easier. retail at £650
£330
Short block
£300 NOW £250
Collection only as I want to ensure buyer is happy. Price is ono.
1380 block
Balanced crank
1275 rods and power max Pistons
Has a good oil pump in it
No cam or followers
Crank taper has a bit of damage
All bearing faces are ok
Bores have very light bore wash
MED S pulley
£50
standard drop gears
£60
Coosie 2WD IC £50
cinq rad has been bent to fit in the front panel better £5
IC with inlet and out let on same side £10
Other one sold
Can post.
Push rods £7
one is bent
Leads for Mega jolts SOLD
£18
Lucas 59D4
Good condition with electronic conversion.
£40
Lucas Coil
£10
4 nearly new revolution type nuts
£4
Lucas metro electronic dizzy with plug.
£60
