Hi, I have just installed a new front to rear brake line on my '95 Cooper spi. I detached the master cylinder from the servo to get better access to the pressure valve union below. After refitting everything and doing a final check I noticed a rubber washer at the bottom of the engine bay. I tried to retrieve it fell out of sight.
I'm concerned that the washer may have detached from the master cylinder. I know there is an O ring seal on the master but the rubber washer I saw was flat and about 1.5 cm across.
Please could anyone advise me on what to look for to check that the O ring seal on the master cylinder is in place? sounds a daft question but is it obvious to check, or is it recessed? I just need reassurance that the washer I saw hadn't fallen out of the master cylinder / servo.
Many thanks
![Photo](https://secure.gravatar.com/avatar/22736b408e1597bce28e33bcd53909de?s=100&d=https%3A%2F%2Fwww.theminiforum.co.uk%2Fforums%2Fpublic%2Fstyle_images%2Ftmf%2Fprofile%2Fdefault_large.png)
O Ring Between Brake Master Cylinder And Servo
MatthewsDad
, Jan 21 2016 07:44 AM
2 replies to this topic
