Just a hypothetical question. (for now)
Does anyone know if a 1275cc head would reduce the compression ratio for a 998cc block with standard pistons and con rods?
Thanks in advance.
Posted 21 January 2016 - 02:59 PM
Thanks in advance.
Posted 21 January 2016 - 03:46 PM
Posted 21 January 2016 - 04:32 PM
If you are considering doing this learn how to do the calculations regarding CR's. Then measure and calculate again.
Posted 21 January 2016 - 06:17 PM
As it's a hypothetical question, a hypothetical answer is no.
Nominally, the 998 head has circa 24.5 cc and the 1275 around 21.5 cc. This would increase the static CR.
But, as Cooperman has suggested, measure what you have and what you're contemplating and run the numbers.
Posted 21 January 2016 - 07:21 PM
Thanks for all the help. When I get round to taking the head off the 998cc I will check the numbers.
After doing some more research it has only confirmed what you have said.
Thanks again.
Posted 21 January 2016 - 09:17 PM
If you are going to fit a 1275 head be aware of the possible clearance issues between valves and block face. Again, you may need a different water pump and pulley and coolant hose routing :)
Posted 21 January 2016 - 10:38 PM
