Mini Jolting/hesitating When Accelerating Through Low Gears
engine
9 replies to this topic
#1 Jordannn
Jordannn
  • 45 posts
Posted 27 January 2016 - 06:35 PM
Hi Guys,
I have a Classic Rover Mini Equinox (1996).
I'll try my best to describe the problem i'm having:
At the START of the journey, usually between 10-20mph in gear 2, my mini starts to jolt forward and is hesitant to accelerate - ranges from 2 seconds to 8ish.
The best way to describe it is it feels like the engine is not getting petrol to it; making it jolt until it starts being fine.
I could be driving at 15mph in gear 2; 10-20 seconds into my journey and it will begin - once it has done it once, it wont happen again until the car has stopped for a while (i.e. next day)
This problem is only intermittent though - it does not occur everyday, but it does it often enough for me to want to sort it out before it gets worse.
If ive missed anything or you need more info to try and help my solve the problem - let me know,
Thanks in advance :)
#2 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 27 January 2016 - 06:48 PM
It sounds like not enough choke while it's cold.  I tend to push my choke in after getting past second gear.  If I have to stop at lights etc I'll pull the choke out again as I'm rolling to a stop.
#3 Spider
  • 15,133 posts
Posted 27 January 2016 - 07:45 PM
Being a 1996 build, it would be an SPI, the Flying Scott's the guy.
#4 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
Posted 27 January 2016 - 07:54 PM
Indeed Chief Inspector Clouseau, it's likely not the choke in that case! :P
#5 Richie83
Richie83
  • 1,495 posts
Posted 27 January 2016 - 07:56 PM
Have you checked all the vacuum hoses? Also I had a similar problem with my Spi. Turned out worn engine steady bushes where causing the engine to move back and forth. As it was doing this it was knocking the air filter sensor in and out. I doubt yours is the same problem, but it's worth a look.
#6 Jordannn
Jordannn
  • 45 posts
Posted 27 January 2016 - 08:08 PM
Thanks guys,
It starts as soon as the key is turned - its really responsive.
Its not necessarily when its cold that it does it; its done it in the summer before.
The best way to put it is it judders (almost as if the engine has no petrol), then all is fine afterwards
There are no strange noises when it happens - just sounds like its ran out of petrol - (its not low on petrol when it does this XD)
Thanks,
#7 Albino_Hedgehog
Albino_Hedgehog
  • 341 posts
  • Local Club: Solihull Mini Classic Club
Posted 27 January 2016 - 08:26 PM
Could it be the spark being the issue?
Had a similar thing with my carb engine and was told the check the dizzy and that cured it for me!
Ps: dunno if that is relevant to your issue
#8 Jordannn
Jordannn
  • 45 posts
Posted 27 January 2016 - 08:32 PM
Sorry,
What do you mean 'the spark'? (spark plugs?)
also, 'check the dizzy'?
I know a tiny bit about minis - but that over my head XD
#9 Albino_Hedgehog
Albino_Hedgehog
  • 341 posts
Posted 27 January 2016 - 10:29 PM
Sorry, I was told to check the Distributor was dry, and not suffering from any Moisture geting into it, due to the recent rainfall
#10 Spider
  • 15,133 posts
Posted 28 January 2016 - 01:14 AM
I'll shut up and stick my head back in it's bucket of sand!
