Replace 1995 Sidewalk Door Check Straps
Best Answer alex-95 , 29 January 2016 - 04:02 PM
Open the door and pull out the pin to remove it from the door. you'll then have to remove your dash  as below you should be able to remove the ball vent and pull it out from there where there will be a big hole in the a-post where the check strap fits it should have a washer and a bit of rubber on it.
Go to the full post
4 replies to this topic
#1 peterej
peterej
    Starting My Mini Up
  • 2 posts
Posted 29 January 2016 - 03:55 PM
Need to replace drivers door check strap (no longer clicking). How do I remove the end attached to the door frame.
All I can see is the flat bar protruding through a square hole which is surrounded by the foam seal. Was told it was probably inside  at corner of parcel shelf. As I have a walnut dash fitted I'm not sure what lies behind.
Any advice very welcome
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,034 posts
Posted 29 January 2016 - 04:02 PM   Best Answer
Edited by alex-95, 29 January 2016 - 08:23 PM.
#3 cal844
cal844
  • 9,637 posts
  • Local Club: TFMOC
Posted 29 January 2016 - 04:58 PM
You can just get to the check strap(I can anyway on my minis with MPI style dash)
#4 AgentHubcap
AgentHubcap
  • 76 posts
Posted 29 January 2016 - 06:19 PM
I was able to replace mine without taking out my dash by just pulling the vent.
#5 peterej
peterej
    Starting My Mini Up
  • 2 posts
Posted 29 January 2016 - 08:13 PM
Thanks for your replies, will now order the bits.
advice appreciated
peterej
