Reverse Gear
21 replies to this topic
#1 I hate Brian
I hate Brian
  • 782 posts
Posted 02 February 2016 - 12:32 PM
Hi can any one give me symptoms for struggling to engage reverse gear ? (93 Cooper SPI) new clutch, arm, slave cylinder other gears are ok
#2 David128
David128
  • 644 posts
Posted 02 February 2016 - 12:34 PM
is it the same with engine not running?
#3 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 02 February 2016 - 12:41 PM
If you pump the pedal 3 times quickly and then try to engage, is it any easier?
#4 I hate Brian
I hate Brian
  • 782 posts
Posted 02 February 2016 - 01:21 PM
Hi chaps, I have snatch it then it clunks into gear, pumping makes no difference.
#5 Swift_General
Swift_General
  • 871 posts
Posted 02 February 2016 - 01:36 PM
If it doesn't do it with then engine stopped it's likely to be the clutch not fully disengaging.
#6 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 02 February 2016 - 01:44 PM
Sounds like clutch to me.
#7 Jono_h
Jono_h
  • 23 posts
Posted 02 February 2016 - 05:47 PM
Slipped bush in reverse gear?
http://www.theminifo...sh#entry3338299
#8 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 02 February 2016 - 08:27 PM
where does the pedal bite? Is it slack for the first inch or so? If someone looks at the arm, does it move immediately you depress the pedal? If someone levers the clutch arm out further as you have fully depressed the pedal, does it go in OK?
#9 I hate Brian
I hate Brian
  • 782 posts
Posted 02 February 2016 - 09:07 PM
pedal bite is fine only reverse is a problem no other gears
#10 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 02 February 2016 - 10:45 PM
Fair enough, just to point out reverse is normally the one gear to demonstrate a problem with a "dragging' clutch
You are welcome by the way :o(
#11 I hate Brian
I hate Brian
  • 782 posts
Posted 03 February 2016 - 07:51 AM
Thanks for the replies everyone including you ChopperHarris  ;D  not sorted it yet so that's why I've been short with responses, a friend has suggested possible reverse gear bearing might have collapsed, causing play ?
#12 Spider
  • 15,684 posts
Posted 03 February 2016 - 08:13 AM
From the descriptions so far, it doesn't sound like Clutch or Primary Gear related. It could be one of a number of items, all internal to the Gearbox, ie, collapsed Mainshaft Nose Bearing, a split baulk ring (rare), damaged Reverse Gear bush, worn Mainshaft bearing or even a badly machined casing (and that's much more common than you may realise!).
So, either way, I'm pretty sure the Gearbox need to come off and apart.
#13 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 03 February 2016 - 10:16 AM
^^^^Mokes  the man.
However, did you replace all the parts you listed particularly because of this problem, or has it occurred since?
#14 I hate Brian
I hate Brian
  • 782 posts
Posted 03 February 2016 - 12:44 PM
Hi Chopper, I replaced the parts to eradicate the fault not wanting to remove the gear box, as per Moke my friend suggested the reverse gear bush might of collapsed.
So engine out again and box off.
Thanks for all the replies gents hopefully see what's going off inside ?
#15 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 03 February 2016 - 03:23 PM
Oh bugger, I wish you luck.
I don't fear anything automotive....except the black art of gearboxes!
